REST API reference
Retrieve lock details
Retrieves details about locks, which can help you understand the current state of locked resources within your environment.
HTTP method and endpoint
GET /protocols/locks
Introduced in
ONTAP 9.10
Usage notes
Retrieves locks details.
  • vserver locks show
path
string
query
False
Filter by path
interface.uuid
string
query
False
Filter by interface.uuid
interface.ip.address
string
query
False
Filter by interface.ip.address
interface.name
string
query
False
Filter by interface.name
delegation
string
query
False
Filter by delegation
protocol
string
query
False
Filter by protocol
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
state
string
query
False
Filter by state
oplock_level
string
query
False
Filter by oplock_level
share_lock.soft
boolean
query
False
Filter by share_lock.soft
share_lock.mode
string
query
False
Filter by share_lock.mode
type
string
query
False
Filter by type
uuid
string
query
False
Filter by uuid
owner_id
string
query
False
Filter by owner_id
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
smb.open_group_id
string
query
False
Filter by smb.open_group_id
smb.open_type
string
query
False
Filter by smb.open_type
smb.connect_state
string
query
False
Filter by smb.connect_state
client_address
string
query
False
Filter by client_address
constituent
boolean
query
False
Filter by constituent
byte_lock.exclusive
boolean
query
False
Filter by byte_lock.exclusive
byte_lock.offset
integer
query
False
Filter by byte_lock.offset
byte_lock.mandatory
boolean
query
False
Filter by byte_lock.mandatory
byte_lock.soft
boolean
query
False
Filter by byte_lock.soft
byte_lock.super
boolean
query
False
Filter by byte_lock.super
byte_lock.length
integer
query
False
Filter by byte_lock.length
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[client_lock]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "byte_lock": {
        "length": 10,
        "offset": 100
      "client_address": "0.0.0.0",
      "delegation": "string",
      "interface": {
        "ip": {
          "address": "10.10.10.7"
        "name": "lif1",
      "node": {
        "name": "node1",
      "oplock_level": "string",
      "owner_id": "string",
      "path": "string",
      "protocol": "string",
      "share_lock": {
        "mode": "string"
      "smb": {
        "connect_state": "string",
        "open_group_id": "string",
        "open_type": "string"
      "state": "string",
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "ceeac1b4-8646-4c76-a054-1c96e87594aa",
      "volume": {
        "name": "volume1",
Status: Default, Unexpected error_response
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
byte_lock
exclusive
boolean
Indicates whether it is an exclusive bytelock.
length
integer
Length of the bytelock starting from the offset.
mandatory
boolean
Indicates whether or not the bytelock is mandatory.
offset
integer
Starting offset for a bytelock.
soft
boolean
Indicates whether it is a soft bytelock.
super
boolean
Indicates whether it is a super bytelock.
self
ip
IP information
address
string
IPv4 or IPv6 address
interface
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
node
_links
_links
name
string
uuid
string
share_lock
mode
string
Types of share lock modes.
soft
boolean
Indicates whether it is a soft share lock.
smb
connect_state
string
SMB connection state.
open_group_id
string
SMB open group ID.
open_type
string
SMB open type.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
client_lock
This object represents locks on a volume.
byte_lock
byte_lock
client_address
string
IP address of the client holding the lock.
constituent
boolean
Indicate if volume is contituent or not.
delegation
string
Type of delegation.
interface
interface
node
node
oplock_level
string
The oplock level determines which operations the client may cache locally.
owner_id
string
Owner ID.
path
string
Object path
protocol
string
Type of lock protocol.
share_lock
share_lock
smb
smb
state
string
State of lock.
svm
svm
type
string
Type of lock.
uuid
string
Lock UUID
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
