Retrieve lock details
GET /protocols/locks
Introduced In: 9.10
Retrieves locks details.
Related ONTAP commands
vserver locks show
protocol |
string |
query |
False |
Filter by protocol |
state |
string |
query |
False |
Filter by state |
byte_lock.soft |
boolean |
query |
False |
Filter by byte_lock.soft |
byte_lock.mandatory |
boolean |
query |
False |
Filter by byte_lock.mandatory |
byte_lock.super |
boolean |
query |
False |
Filter by byte_lock.super |
byte_lock.offset |
integer |
query |
False |
Filter by byte_lock.offset |
byte_lock.length |
integer |
query |
False |
Filter by byte_lock.length |
byte_lock.exclusive |
boolean |
query |
False |
Filter by byte_lock.exclusive |
type |
string |
query |
False |
Filter by type |
owner_id |
string |
query |
False |
Filter by owner_id |
smb.open_type |
string |
query |
False |
Filter by smb.open_type |
smb.connect_state |
string |
query |
False |
Filter by smb.connect_state |
smb.open_group_id |
string |
query |
False |
Filter by smb.open_group_id |
delegation |
string |
query |
False |
Filter by delegation |
uuid |
string |
query |
False |
Filter by uuid |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
constituent |
boolean |
query |
False |
Filter by constituent |
client_address |
string |
query |
False |
Filter by client_address |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
path |
string |
query |
False |
Filter by path |
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
interface.name |
string |
query |
False |
Filter by interface.name |
interface.ip.address |
string |
query |
False |
Filter by interface.ip.address |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
oplock_level |
string |
query |
False |
Filter by oplock_level |
share_lock.soft |
boolean |
query |
False |
Filter by share_lock.soft |
share_lock.mode |
string |
query |
False |
Filter by share_lock.mode |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[client_lock] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"byte_lock": {
"length": "10",
"offset": "100"
"client_address": "0.0.0.0",
"delegation": "string",
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"node": {
"name": "node1",
"oplock_level": "string",
"owner_id": "string",
"path": "string",
"protocol": "string",
"share_lock": {
"mode": "string"
"smb": {
"connect_state": "string",
"open_group_id": "string",
"open_type": "string"
"state": "string",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "ceeac1b4-8646-4c76-a054-1c96e87594aa",
"volume": {
"name": "volume1",
Status: Default, Unexpected error_response
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
byte_lock
exclusive |
boolean |
Indicates whether it is an exclusive bytelock. |
length |
integer |
Length of the bytelock starting from the offset. |
mandatory |
boolean |
Indicates whether or not the bytelock is mandatory. |
offset |
integer |
Starting offset for a bytelock. |
soft |
boolean |
Indicates whether it is a soft bytelock. |
super |
boolean |
Indicates whether it is a super bytelock. |
_links
self |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
node
_links |
name |
string |
uuid |
string |
mode |
string |
Types of share lock modes. |
soft |
boolean |
Indicates whether it is a soft share lock. |
smb
connect_state |
string |
SMB connection state. |
open_group_id |
string |
SMB open group ID. |
open_type |
string |
SMB open type. |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
client_lock
This object represents locks on a volume.
byte_lock |
client_address |
string |
IP address of the client holding the lock. |
constituent |
boolean |
Indicate if volume is constituent or not. |
delegation |
string |
Type of delegation. |
interface |
A network interface. Either UUID or name may be supplied on input. |
node |
oplock_level |
string |
The oplock level determines which operations the client may cache locally. |
owner_id |
string |
Owner ID. |
path |
string |
Object path |
protocol |
string |
Type of lock protocol. |
share_lock |
smb |
state |
string |
State of lock. |
svm |
type |
string |
Type of lock. |
uuid |
string |
Lock UUID |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
