REST API reference
Retrieve NFS protocol historical performance metrics
Obtains historical performance metrics for the NFS protocol of an SVM, which helps you analyze past performance trends.
HTTP method and endpoint
GET /protocols/nfs/services/{svm.uuid}/metrics
Introduced in
ONTAP 9.7
Usage notes
Retrieves historical performance metrics for the NFS protocol of an SVM.
v3.latency.other
integer
query
False
Filter by v3.latency.other
v3.latency.read
integer
query
False
Filter by v3.latency.read
v3.latency.write
integer
query
False
Filter by v3.latency.write
v3.latency.total
integer
query
False
Filter by v3.latency.total
v3.iops.other
integer
query
False
Filter by v3.iops.other
v3.iops.read
integer
query
False
Filter by v3.iops.read
v3.iops.write
integer
query
False
Filter by v3.iops.write
v3.iops.total
integer
query
False
Filter by v3.iops.total
v3.throughput.write
integer
query
False
Filter by v3.throughput.write
v3.throughput.total
integer
query
False
Filter by v3.throughput.total
v3.throughput.read
integer
query
False
Filter by v3.throughput.read
v3.status
string
query
False
Filter by v3.status
v3.duration
string
query
False
Filter by v3.duration
timestamp
string
query
False
Filter by timestamp
v41.latency.other
integer
query
False
Filter by v41.latency.other
  • Introduced in: 9.8
v41.latency.read
integer
query
False
Filter by v41.latency.read
v41.latency.write
integer
query
False
Filter by v41.latency.write
v41.latency.total
integer
query
False
Filter by v41.latency.total
v41.iops.other
integer
query
False
Filter by v41.iops.other
v41.iops.read
integer
query
False
Filter by v41.iops.read
v41.iops.write
integer
query
False
Filter by v41.iops.write
v41.iops.total
integer
query
False
Filter by v41.iops.total
v41.throughput.write
integer
query
False
Filter by v41.throughput.write
v41.throughput.total
integer
query
False
Filter by v41.throughput.total
v41.throughput.read
integer
query
False
Filter by v41.throughput.read
v41.status
string
query
False
Filter by v41.status
v41.duration
string
query
False
Filter by v41.duration
v4.status
string
query
False
Filter by v4.status
v4.throughput.write
integer
query
False
Filter by v4.throughput.write
v4.throughput.total
integer
query
False
Filter by v4.throughput.total
v4.throughput.read
integer
query
False
Filter by v4.throughput.read
v4.duration
string
query
False
Filter by v4.duration
v4.latency.other
integer
query
False
Filter by v4.latency.other
v4.latency.read
integer
query
False
Filter by v4.latency.read
v4.latency.write
integer
query
False
Filter by v4.latency.write
v4.latency.total
integer
query
False
Filter by v4.latency.total
v4.iops.other
integer
query
False
Filter by v4.iops.other
v4.iops.read
integer
query
False
Filter by v4.iops.read
v4.iops.write
integer
query
False
Filter by v4.iops.write
v4.iops.total
integer
query
False
Filter by v4.iops.total
svm.uuid
string
path
True
Unique identifier of the SVM.
interval
string
query
False
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
  • 1h: Metrics over the most recent hour sampled over 15 seconds.
  • 1d: Metrics over the most recent day sampled over 5 minutes.
  • 1w: Metrics over the most recent week sampled over 30 minutes.
  • 1m: Metrics over the most recent month sampled over 2 hours.
  • 1y: Metrics over the most recent year sampled over a day.
  • Default value: 1
  • enum: ["1h", "1d", "1w", "1m", "1y"]
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
return_records
boolean
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "v3": {
        "duration": "PT15S",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
        "timestamp": "2017-01-25T11:20:13Z"
      "v4": {
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
      "v41": {
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
v3
The NFSv3 operations
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
v4
The NFSv4 operations
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
v41
The NFSv4.1 operations
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
records
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
