Retrieve NFS protocol historical performance metrics
Accesses historical performance metrics for the NFS protocol of an SVM to analyze past data and trends.
HTTP method and endpoint
GET /protocols/nfs/services/{svm.uuid}/metrics
Introduced in
ONTAP 9.7
Usage notes
Retrieves historical performance metrics for the NFS protocol of an SVM.
v3.latency.write |
integer |
query |
False |
Filter by v3.latency.write |
v3.latency.total |
integer |
query |
False |
Filter by v3.latency.total |
v3.latency.read |
integer |
query |
False |
Filter by v3.latency.read |
v3.latency.other |
integer |
query |
False |
Filter by v3.latency.other |
v3.duration |
string |
query |
False |
Filter by v3.duration |
v3.throughput.total |
integer |
query |
False |
Filter by v3.throughput.total |
v3.throughput.write |
integer |
query |
False |
Filter by v3.throughput.write |
v3.throughput.read |
integer |
query |
False |
Filter by v3.throughput.read |
v3.status |
string |
query |
False |
Filter by v3.status |
v3.iops.write |
integer |
query |
False |
Filter by v3.iops.write |
v3.iops.total |
integer |
query |
False |
Filter by v3.iops.total |
v3.iops.read |
integer |
query |
False |
Filter by v3.iops.read |
v3.iops.other |
integer |
query |
False |
Filter by v3.iops.other |
v4.iops.write |
integer |
query |
False |
Filter by v4.iops.write
v4.iops.total |
integer |
query |
False |
Filter by v4.iops.total
v4.iops.read |
integer |
query |
False |
Filter by v4.iops.read
v4.iops.other |
integer |
query |
False |
Filter by v4.iops.other
v4.status |
string |
query |
False |
Filter by v4.status
v4.duration |
string |
query |
False |
Filter by v4.duration
v4.latency.write |
integer |
query |
False |
Filter by v4.latency.write
v4.latency.total |
integer |
query |
False |
Filter by v4.latency.total
v4.latency.read |
integer |
query |
False |
Filter by v4.latency.read
v4.latency.other |
integer |
query |
False |
Filter by v4.latency.other
v4.throughput.total |
integer |
query |
False |
Filter by v4.throughput.total
v4.throughput.write |
integer |
query |
False |
Filter by v4.throughput.write
v4.throughput.read |
integer |
query |
False |
Filter by v4.throughput.read
timestamp |
string |
query |
False |
Filter by timestamp |
v41.throughput.total |
integer |
query |
False |
Filter by v41.throughput.total
v41.throughput.write |
integer |
query |
False |
Filter by v41.throughput.write
v41.throughput.read |
integer |
query |
False |
Filter by v41.throughput.read
v41.duration |
string |
query |
False |
Filter by v41.duration
v41.latency.write |
integer |
query |
False |
Filter by v41.latency.write
v41.latency.total |
integer |
query |
False |
Filter by v41.latency.total
v41.latency.read |
integer |
query |
False |
Filter by v41.latency.read
v41.latency.other |
integer |
query |
False |
Filter by v41.latency.other
v41.iops.write |
integer |
query |
False |
Filter by v41.iops.write
v41.iops.total |
integer |
query |
False |
Filter by v41.iops.total
v41.iops.read |
integer |
query |
False |
Filter by v41.iops.read
v41.iops.other |
integer |
query |
False |
Filter by v41.iops.other
v41.status |
string |
query |
False |
Filter by v41.status
svm.uuid |
string |
path |
True |
Unique identifier of the SVM. |
interval |
string |
query |
False |
The time range for the data. Examples can be 1h, 1d, 1m, 1w, 1y. The period for each time range is as follows:
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
return_records |
boolean |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"v3": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 06:20:13 -0500"
"v4": {
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"v41": {
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
v3
The NFSv3 operations
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
v4
The NFSv4 operations
_links |
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
v41
The NFSv4.1 operations
_links |
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
records
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
The NFSv3 operations |
v4 |
The NFSv4 operations |
v41 |
The NFSv4.1 operations |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
