Retrieve initiators of an initiator group
Retrieves the initiators of an initiator group to identify which initiators are directly associated with it. This is useful for managing and auditing SAN configurations.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/initiators
Introduced in
ONTAP 9.6
Usage notes
This API only reports initiators owned directly by the initiator group. Initiators of nested initiator groups are not included in this collection.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
connectivity_tracking.*
Related ONTAP commands
lun igroup show
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[igroup_initiator] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "string",
"connectivity_tracking": {
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"connection_state": "string",
"connections": [
"logins": [
"interface": {
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"last_seen_time": "2021-03-14T05:19:00Z"
"node": {
"name": "node1",
"igroup": {
"name": "igroup1",
"name": "iqn.1998-01.com.corp.iscsi:name1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852 |
The initiator group specified in the URI does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
alerts
summary |
A user friendly message describing the connection state. |
fc
An FC interface.
_links |
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
address |
string |
IPv4 or IPv6 address |
ip
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
interface
fc |
An FC interface. |
ip |
logins
connected |
boolean |
True if the initiator is currently logged in to this connection's interface. |
interface |
last_seen_time |
string |
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported. |
node
_links |
name |
string |
uuid |
string |
connections
logins |
array[logins] |
node |
Overview of the initiator's connections to ONTAP.
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
connections |
array[connections] |
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
records
_links |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
igroup_initiator
_links |
comment |
string |
connectivity_tracking |
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
name |
string |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
