REST API reference
Retrieve initiators of an initiator group
Retrieves initiators of an initiator group to view the specific initiators owned directly by that group, excluding those from nested groups.
HTTP method and endpoint
GET /protocols/san/igroups/{igroup.uuid}/initiators
Introduced in
ONTAP 9.6
Usage notes
This API only reports initiators owned directly by the initiator group. Initiators of nested initiator groups are not included in this collection.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connectivity_tracking.*
  • lun igroup show
igroup.uuid
string
path
True
The unique identifier of the initiator group.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[igroup_initiator]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "connectivity_tracking": {
        "alerts": [
            "summary": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "message": "entry doesn't exist"
        "connection_state": "string",
        "connections": [
            "logins": [
                "interface": {
                  "fc": {
                    "name": "fc_lif1",
                    "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
                    "wwpn": "20:00:00:50:56:b4:13:a8"
                  "ip": {
                    "ip": {
                      "address": "10.10.10.7"
                    "name": "lif1",
                "last_seen_time": "2021-03-14 00:19:00 -0500"
            "node": {
              "name": "node1",
      "igroup": {
        "name": "igroup1",
      "name": "iqn.1998-01.com.corp.iscsi:name1",
      "proximity": {
        "peer_svms": [
            "name": "peer1",
            "uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
Status: Default
ONTAP Error Response Codes
Error Code Description
5374852
The initiator group specified in the URI does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
alerts
summary
summary
fc
An FC interface.
_links
_links
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
address
string
IPv4 or IPv6 address
ip
A network interface. Either UUID or name may be supplied on input.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interface
fc
fc
An FC interface.
ip
ip
logins
connected
boolean
True if the initiator is currently logged in to this connection's interface.
interface
interface
last_seen_time
string
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported.
node
_links
_links
name
string
uuid
string
connections
logins
array[logins]
node
node
Overview of the initiator's connections to ONTAP.
alerts
array[alerts]
connection_state
string
Connection state.
connections
array[connections]
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
_links
_links
name
string
The name of the initiator group.
uuid
string
peer_svms
A reference to an SVM peer relationship.
_links
_links
name
string
The local name of the peer SVM. This name is unique among all local and peer SVMs.
uuid
string
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself.
proximity
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for an initiator, the sub-object will not be present in GET.
These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The proximity sub-object for an initiator is set in POST and PATCH in its entirety and replaces any previously set proximity for the initiator within the SVM for the initiator within the SVM. The local_svm property must always be set to true or false when setting the proximity property. To clear any previously set proximity, POST or PATCH the proximity object to null.
local_svm
boolean
A boolean that indicates if the initiator is proximal to the SVM of the containing initiator group. This is required for any POST or PATCH that includes the proximity sub-object.
peer_svms
array[peer_svms]
An array of remote peer SVMs to which the initiator is proximal.
records
_links
_links
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
proximity
proximity
igroup_initiator
_links
_links
comment
string
  • readOnly: 1
  • Introduced in: 9.11
igroup
igroup
name
string
proximity
proximity
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
