REST API reference
Retrieve an iSCSI session
Retrieves information about an iSCSI session to monitor and manage active connections in your storage environment.
HTTP method and endpoint
GET /protocols/san/iscsi/sessions/{svm.uuid}/{tpgroup}/{tsih}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an iSCSI session.
  • vserver iscsi connection show
  • vserver iscsi session parameter show
  • vserver iscsi session show
svm.uuid
string
path
True
The unique identifier of the SVM of the iSCSI session.
tpgroup
string
path
True
The target portal group of the iSCSI session.
tsih
integer
path
True
The target session identifying handle.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
connections
array[iscsi_connection]
The iSCSI connections that make up the iSCSI session.
igroups
array[igroups]
The initiator groups in which the initiator is a member.
initiator
initiator
The initiator that created the session.
isid
string
The initiator portion of the session identifier specified by the initiator during login.
svm
svm
target_portal_group
string
The target portal group to which the session belongs.
target_portal_group_tag
integer
The target portal group tag of the session.
tsih
integer
The target session identifier handle (TSIH) of the session.
      "href": "/api/resourcelink"
  "connections": [
        "next": {
      "authentication_type": "string",
      "cid": 0,
      "initiator_address": {
        "address": "10.10.10.7",
        "port": 55432
      "interface": {
        "ip": {
          "port": 3260
        "name": "lif1",
  "igroups": [
      "name": "igroup1",
  "initiator": {
    "alias": "initiator_alias1",
    "comment": "This is an iSCSI initiator for host 5",
    "name": "iqn.1992-01.example.com:string"
  "isid": "61:62:63:64:65:00",
  "svm": {
    "name": "svm1",
  "target_portal_group": "tpgroup1",
  "target_portal_group_tag": 0,
  "tsih": 0
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
next
self
initiator_address
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging.
address
string
The TCP IPv4 or IPv6 address of the initiator end of the iSCSI connection.
port
integer
The TCP port number of the initiator end of the iSCSI connection.
ip
The IP information. ONTAP only supports port 3260.
address
string
port
integer
The TCP port number of the iSCSI access endpoint.
interface
The network interface information for the target end of the connection.
_links
_links
ip
ip
  • readOnly: 1
  • Introduced in: 9.6
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
iscsi_connection
An active iSCSI connection.
_links
_links
authentication_type
string
The iSCSI authentication type used to establish the connection.
cid
integer
The identifier of the connection within the session.
initiator_address
initiator_address
interface
interface
igroups
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiator
alias
string
The initiator alias.
comment
string
A comment available for use by the administrator. This is modifiable from the initiator REST endpoint directly. See PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name} .
name
string
The world wide unique name of the initiator.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
