Retrieve an iSCSI session
Retrieves details about an iSCSI session, which can help you understand the current state and configuration of your SAN environment.
HTTP method and endpoint
GET /protocols/san/iscsi/sessions/{svm.uuid}/{tpgroup}/{tsih}
Introduced in
ONTAP 9.6
Usage notes
Retrieves an iSCSI session.
Related ONTAP commands
vserver iscsi connection show -
vserver iscsi session parameter show -
vserver iscsi session show
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of the SVM of the iSCSI session. |
tpgroup |
string |
path |
True |
The target portal group of the iSCSI session. |
tsih |
integer |
path |
True |
The target session identifying handle. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
connections |
array[iscsi_connection] |
The iSCSI connections that make up the iSCSI session. |
igroups |
array[igroups] |
The initiator groups in which the initiator is a member. |
initiator |
The initiator that created the session. |
isid |
string |
The initiator portion of the session identifier specified by the initiator during login. |
svm |
target_portal_group |
string |
The target portal group to which the session belongs. |
target_portal_group_tag |
integer |
The target portal group tag of the session. |
tsih |
integer |
The target session identifier handle (TSIH) of the session. |
"href": "/api/resourcelink"
"connections": [
"next": {
"authentication_type": "string",
"cid": 0,
"initiator_address": {
"address": "10.10.10.7",
"port": 55432
"interface": {
"ip": {
"port": 3260
"name": "lif1",
"igroups": [
"name": "igroup1",
"initiator": {
"alias": "initiator_alias1",
"comment": "This is an iSCSI initiator for host 5",
"name": "iqn.1992-01.example.com:string"
"isid": "61:62:63:64:65:00",
"svm": {
"name": "svm1",
"target_portal_group": "tpgroup1",
"target_portal_group_tag": 0,
"tsih": 0
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
_links
next |
self |
initiator_address
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging.
address |
string |
The TCP IPv4 or IPv6 address of the initiator end of the iSCSI connection. |
port |
integer |
The TCP port number of the initiator end of the iSCSI connection. |
ip
The IP information. ONTAP only supports port 3260.
address |
string |
IPv4 or IPv6 address |
port |
integer |
The TCP port number of the iSCSI access endpoint. |
interface
The network interface information for the target end of the connection.
_links |
ip |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
iscsi_connection
An active iSCSI connection.
_links |
authentication_type |
string |
The iSCSI authentication type used to establish the connection. |
cid |
integer |
The identifier of the connection within the session. |
initiator_address |
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging. |
interface |
The network interface information for the target end of the connection. |
igroups
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
initiator
alias |
string |
The initiator alias. |
comment |
string |
A comment available for use by the administrator. This is modifiable from the initiator REST endpoint directly. See PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name} . |
name |
string |
The world wide unique name of the initiator. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
