REST API reference
Retrieves iscsi sessions
  • vserver iscsi session parameter show
  • vserver iscsi session show # learn more
  • [doc /protocols/san/iscsi/sessions](#docs-san-protocols_san_iscsi_sessions)
GET /protocols/san/iscsi/sessions
Introduced In: 9.6
Retrieves iSCSI sessions.
  • vserver iscsi connection show
igroups.uuid
string
query
False
Filter by igroups.uuid
igroups.name
string
query
False
Filter by igroups.name
  • maxLength: 96
  • minLength: 1
tsih
integer
query
False
Filter by tsih
target_portal_group
string
query
False
Filter by target_portal_group
connections.initiator_address.port
integer
query
False
Filter by connections.initiator_address.port
connections.initiator_address.address
string
query
False
Filter by connections.initiator_address.address
connections.cid
integer
query
False
Filter by connections.cid
connections.authentication_type
string
query
False
Filter by connections.authentication_type
connections.interface.uuid
string
query
False
Filter by connections.interface.uuid
connections.interface.ip.address
string
query
False
Filter by connections.interface.ip.address
connections.interface.ip.port
integer
query
False
Filter by connections.interface.ip.port
  • Max value: 65536
  • Min value: 1
connections.interface.name
string
query
False
Filter by connections.interface.name
initiator.name
string
query
False
Filter by initiator.name
initiator.comment
string
query
False
Filter by initiator.comment
  • Introduced in: 9.9
initiator.alias
string
query
False
Filter by initiator.alias
isid
string
query
False
Filter by isid
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
target_portal_group_tag
integer
query
False
Filter by target_portal_group_tag
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[iscsi_session]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "connections": [
            "next": {
          "authentication_type": "string",
          "cid": 0,
          "initiator_address": {
            "address": "10.10.10.7",
            "port": 55432
          "interface": {
            "ip": {
              "port": 3260
            "name": "lif1",
      "igroups": [
          "name": "igroup1",
      "initiator": {
        "alias": "initiator_alias1",
        "comment": "This is an iSCSI initiator for host 5",
        "name": "iqn.1992-01.example.com:string"
      "isid": "61:62:63:64:65:00",
      "svm": {
        "name": "svm1",
      "target_portal_group": "tpgroup1",
      "target_portal_group_tag": 0,
      "tsih": 0
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
initiator_address
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging.
address
string
The TCP IPv4 or IPv6 address of the initiator end of the iSCSI connection.
port
integer
The TCP port number of the initiator end of the iSCSI connection.
ip
The IP information. ONTAP only supports port 3260.
address
string
port
integer
The TCP port number of the iSCSI access endpoint.
interface
The network interface information for the target end of the connection.
_links
_links
ip
ip
  • readOnly: 1
  • Introduced in: 9.6
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
iscsi_connection
An active iSCSI connection.
_links
_links
authentication_type
string
The iSCSI authentication type used to establish the connection.
cid
integer
The identifier of the connection within the session.
initiator_address
initiator_address
interface
interface
igroups
_links
_links
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
initiator
The initiator that created the session.
alias
string
The initiator alias.
comment
string
A comment available for use by the administrator. This is modifiable from the initiator REST endpoint directly. See PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name} .
name
string
The world wide unique name of the initiator.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
iscsi_session
An iSCSI session is one or more TCP connections that link an iSCSI initiator with an iSCSI target. TCP connections can be added and removed from an iSCSI session by the iSCSI initiator. Across all TCP connections within an iSCSI session, an initiator sees one and the same target. After the connection is established, iSCSI control, data, and status messages are communicated over the session.
_links
_links
connections
array[iscsi_connection]
The iSCSI connections that make up the iSCSI session.
igroups
array[igroups]
The initiator groups in which the initiator is a member.
initiator
initiator
isid
string
The initiator portion of the session identifier specified by the initiator during login.
svm
svm
target_portal_group
string
The target portal group to which the session belongs.
integer
The target portal group tag of the session.
tsih
integer
The target session identifier handle (TSIH) of the session.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
