Retrieve iSCSI sessions
Retrieves information about iSCSI sessions, which can help you monitor and manage your iSCSI storage connections.
HTTP method and endpoint
GET /protocols/san/iscsi/sessions
Introduced in
ONTAP 9.6
Usage notes
Retrieves iSCSI sessions.
Related ONTAP commands
vserver iscsi connection show -
vserver iscsi session parameter show -
vserver iscsi session show
Learn more
target_portal_group_tag |
integer |
query |
False |
Filter by target_portal_group_tag |
initiator.alias |
string |
query |
False |
Filter by initiator.alias |
initiator.name |
string |
query |
False |
Filter by initiator.name |
initiator.comment |
string |
query |
False |
Filter by initiator.comment
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
isid |
string |
query |
False |
Filter by isid |
connections.interface.name |
string |
query |
False |
Filter by connections.interface.name |
connections.interface.uuid |
string |
query |
False |
Filter by connections.interface.uuid |
connections.interface.ip.address |
string |
query |
False |
Filter by connections.interface.ip.address |
connections.interface.ip.port |
integer |
query |
False |
Filter by connections.interface.ip.port
connections.cid |
integer |
query |
False |
Filter by connections.cid |
connections.authentication_type |
string |
query |
False |
Filter by connections.authentication_type |
connections.initiator_address.port |
integer |
query |
False |
Filter by connections.initiator_address.port |
connections.initiator_address.address |
string |
query |
False |
Filter by connections.initiator_address.address |
igroups.uuid |
string |
query |
False |
Filter by igroups.uuid |
igroups.name |
string |
query |
False |
Filter by igroups.name
target_portal_group |
string |
query |
False |
Filter by target_portal_group |
tsih |
integer |
query |
False |
Filter by tsih |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[iscsi_session] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"connections": [
"next": {
"authentication_type": "string",
"cid": 0,
"initiator_address": {
"address": "10.10.10.7",
"port": 55432
"interface": {
"ip": {
"port": 3260
"name": "lif1",
"igroups": [
"name": "igroup1",
"initiator": {
"alias": "initiator_alias1",
"comment": "This is an iSCSI initiator for host 5",
"name": "iqn.1992-01.example.com:string"
"isid": "61:62:63:64:65:00",
"svm": {
"name": "svm1",
"target_portal_group": "tpgroup1",
"target_portal_group_tag": 0,
"tsih": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
initiator_address
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging.
address |
string |
The TCP IPv4 or IPv6 address of the initiator end of the iSCSI connection. |
port |
integer |
The TCP port number of the initiator end of the iSCSI connection. |
ip
The IP information. ONTAP only supports port 3260.
address |
string |
IPv4 or IPv6 address |
port |
integer |
The TCP port number of the iSCSI access endpoint. |
interface
The network interface information for the target end of the connection.
_links |
ip |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
iscsi_connection
An active iSCSI connection.
_links |
string |
The iSCSI authentication type used to establish the connection. |
cid |
integer |
The identifier of the connection within the session. |
initiator_address |
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging. |
interface |
The network interface information for the target end of the connection. |
igroups
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
initiator
The initiator that created the session.
alias |
string |
The initiator alias. |
comment |
string |
A comment available for use by the administrator. This is modifiable from the initiator REST endpoint directly. See PATCH /protocols/san/igroups/{igroup.uuid}/initiators/{name} . |
name |
string |
The world wide unique name of the initiator. |
svm
_links |
name |
string |
uuid |
string |
iscsi_session
An iSCSI session is one or more TCP connections that link an iSCSI initiator with an iSCSI target. TCP connections can be added and removed from an iSCSI session by the iSCSI initiator. Across all TCP connections within an iSCSI session, an initiator sees one and the same target. After the connection is established, iSCSI control, data, and status messages are communicated over the session.
_links |
connections |
array[iscsi_connection] |
The iSCSI connections that make up the iSCSI session. |
igroups |
array[igroups] |
The initiator groups in which the initiator is a member. |
initiator |
The initiator that created the session. |
isid |
string |
The initiator portion of the session identifier specified by the initiator during login. |
svm |
string |
The target portal group to which the session belongs. |
integer |
The target portal group tag of the session. |
tsih |
integer |
The target session identifier handle (TSIH) of the session. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
