Retrieve iSCSI sessions
GET /protocols/san/iscsi/sessions
Retrieves iSCSI sessions.
Related ONTAP commands
vserver iscsi connection show -
vserver iscsi session parameter show -
vserver iscsi session show
Learn more
tsih |
integer |
query |
False |
Filter by tsih |
initiator.alias |
string |
query |
False |
Filter by initiator.alias |
initiator.name |
string |
query |
False |
Filter by initiator.name |
isid |
string |
query |
False |
Filter by isid |
igroups.uuid |
string |
query |
False |
Filter by igroups.uuid |
igroups.name |
string |
query |
False |
Filter by igroups.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
target_portal_group_tag |
integer |
query |
False |
Filter by target_portal_group_tag |
connections.authentication_type |
string |
query |
False |
Filter by connections.authentication_type |
connections.initiator_address.port |
integer |
query |
False |
Filter by connections.initiator_address.port |
connections.initiator_address.address |
string |
query |
False |
Filter by connections.initiator_address.address |
connections.cid |
integer |
query |
False |
Filter by connections.cid |
connections.interface.name |
string |
query |
False |
Filter by connections.interface.name |
connections.interface.uuid |
string |
query |
False |
Filter by connections.interface.uuid |
connections.interface.ip.address |
string |
query |
False |
Filter by connections.interface.ip.address |
connections.interface.ip.port |
integer |
query |
False |
Filter by connections.interface.ip.port |
target_portal_group |
string |
query |
False |
Filter by target_portal_group |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[iscsi_session] |
"next": {
"href": "/api/resourcelink"
"records": [
"connections": [
"next": {
"authentication_type": "string",
"cid": 0,
"initiator_address": {
"address": "10.10.10.7",
"port": 55432
"interface": {
"ip": {
"port": 3260
"name": "lif1",
"igroups": [
"name": "igroup1",
"initiator": {
"alias": "initiator_alias1",
"name": "iqn.1992-01.example.com:string"
"isid": "61:62:63:64:65:00",
"svm": {
"name": "svm1",
"target_portal_group": "tpgroup1",
"target_portal_group_tag": 0,
"tsih": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
initiator_address
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging.
address |
string |
The TCP IPv4 or IPv6 address of the initiator end of the iSCSI connection. |
port |
integer |
The TCP port number of the initiator end of the iSCSI connection. |
ip
The IP information. ONTAP only supports port 3260.
address |
string |
IPv4 or IPv6 address |
port |
integer |
The TCP port number of the iSCSI access endpoint. |
interface
The network interface information for the target end of the connection.
_links |
ip |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
iscsi_connection
An active iSCSI connection.
_links |
string |
The iSCSI authentication type used to establish the connection. |
cid |
integer |
The identifier of the connection within the session. |
initiator_address |
The TCP socket information for the initiator end of the connection. This is useful for network packet debugging. |
interface |
The network interface information for the target end of the connection. |
igroups
_links |
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
initiator
The initiator that created the session.
alias |
string |
The initiator alias. |
name |
string |
The world wide unique name of the initiator. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
iscsi_session
An iSCSI session is one or more TCP connections that link an iSCSI initiator with an iSCSI target. TCP connections can be added and removed from an iSCSI session by the iSCSI initiator. Across all TCP connections within an iSCSI session, an initiator sees one and the same target. After the connection is established, iSCSI control, data, and status messages are communicated over the session.
_links |
connections |
array[iscsi_connection] |
The iSCSI connections that make up the iSCSI session. |
igroups |
array[igroups] |
The initiator groups in which the initiator is a member. |
initiator |
The initiator that created the session. |
isid |
string |
The initiator portion of the session identifier specified by the initiator during login. |
svm |
string |
The target portal group to which the session belongs. |
integer |
The target portal group tag of the session. |
tsih |
integer |
The target session identifier handle (TSIH) of the session. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
