Retrieve a LUN map
Retrieves a LUN map to view the mapping details of logical unit numbers (LUNs) for storage management and configuration.
HTTP method and endpoint
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
lun mapping show
Learn more
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
igroup |
The initiator group to which the LUN is mapped. Required in POST by supplying either the |
logical_unit_number |
integer |
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
lun |
The LUN to which the initiator group is mapped. Required in POST by supplying either the |
reporting_nodes |
array[reporting_nodes] |
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP. When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property For further information, see DOC /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes .
svm |
"href": "/api/resourcelink"
"igroup": {
"initiators": [
"iqn.1998-01.com.corp.iscsi:name1"
"name": "igroup1",
"os_type": "string",
"protocol": "string",
"uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
"logical_unit_number": 1,
"lun": {
"name": "/vol/volume1/qtree1/lun1",
"node": {
"name": "node1",
"uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
"reporting_nodes": [
"node": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374852 |
The initiator group does not exist or is not accessible to the caller. |
5374875 |
The LUN does not exist or is not accessible to the caller. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
_links |
initiators |
array[string] |
The initiators that are members of the initiator group. |
name |
string |
The name of the initiator group. Valid in POST. |
os_type |
string |
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system. |
protocol |
string |
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group. |
uuid |
string |
The unique identifier of the initiator group. Valid in POST. |
node
The LUN node.
_links |
name |
string |
The name the LUN's node. |
uuid |
string |
The unique identifier of the LUN node. |
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
_links |
name |
string |
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST. |
node |
The LUN node. |
uuid |
string |
The unique identifier of the LUN. Valid in POST. |
_links
node |
self |
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
