REST API reference
Retrieve a LUN map
Retrieves information about a LUN map, helping you understand the mapping configuration for storage resources.
HTTP method and endpoint
GET /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a LUN map.
  • lun mapping show
lun.uuid
string
path
True
The unique identifier of the LUN.
igroup.uuid
string
path
True
The unique identifier of the igroup.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
igroup
igroup
The initiator group to which the LUN is mapped. Required in POST by supplying either the igroup.uuid, igroup.name, or both.
logical_unit_number
integer
The logical unit number assigned to the LUN when mapped to the specified initiator group. The number is used to identify the LUN to initiators in the initiator group when communicating through Fibre Channel Protocol or iSCSI. Optional in POST; if no value is provided, ONTAP assigns the lowest available value.
  • example: 1
  • Max value: 4095
  • Min value: 0
  • Introduced in: 9.6
  • readCreate: 1
  • x-nullable: true
lun
lun
The LUN to which the initiator group is mapped. Required in POST by supplying either the lun.uuid, lun.name, or both.
reporting_nodes
array[reporting_nodes]
The cluster nodes from which network paths to the mapped LUNs are advertised via the SAN protocols as part of the Selective LUN Map (SLM) feature of ONTAP.
When a LUN map is created, the cluster node hosting the LUN and its high availability (HA) partner are set as the default reporting node. In POST, the property additional_reporting_node may be used to add an additional node and its HA partner.
  • readOnly: 1
  • Introduced in: 9.10
svm
svm
      "href": "/api/resourcelink"
  "igroup": {
    "initiators": [
      "iqn.1998-01.com.corp.iscsi:name1"
    "name": "igroup1",
    "os_type": "string",
    "protocol": "string",
    "uuid": "1ad8544d-8cd1-91e0-9e1c-723478563412"
  "logical_unit_number": 1,
  "lun": {
    "name": "/vol/volume1/qtree1/lun1",
    "node": {
      "name": "node1",
      "uuid": "1cf8aa42-8cd1-12e0-a11c-423468563412"
  "reporting_nodes": [
        "node": {
      "name": "node1",
      "uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
5374852
The initiator group does not exist or is not accessible to the caller.
5374875
The LUN does not exist or is not accessible to the caller.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
igroup
_links
_links
initiators
array[string]
The initiators that are members of the initiator group.
name
string
The name of the initiator group. Valid in POST.
os_type
string
The host operating system of the initiator group. All initiators in the group should be hosts of the same operating system.
protocol
string
The protocols supported by the initiator group. This restricts the type of initiators that can be added to the initiator group.
uuid
string
The unique identifier of the initiator group. Valid in POST.
node
The LUN node.
_links
_links
name
string
The name the LUN's node.
uuid
string
The unique identifier of the LUN node.
lun
_links
_links
name
string
The fully qualified path name of the LUN composed of a "/vol" prefix, the volume name, the (optional) qtree name, and file name of the LUN. Valid in POST.
node
node
The LUN node.
uuid
string
The unique identifier of the LUN. Valid in POST.
node
self
reporting_nodes
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links
_links
name
string
The name of the node.
Either uuid or name are required in POST.
uuid
string
The unique identifier of the node.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
