Retrieve a vVol binding
Retrieves a virtual volume (vVol) binding to access information about its current configuration and status. Use this operation to monitor or manage vVol resources effectively.
HTTP method and endpoint
GET /protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
Introduced in
ONTAP 9.10
Usage notes
Retrieves a vVol binding.
Related ONTAP commands
lun bind show
Learn more
protocol_endpoint.uuid |
string |
path |
True |
The unique identifier of the class |
vvol.uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
count |
integer |
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter |
id |
integer |
The identifier assigned to the vVol binding. The bind identifier is unique amongst all class |
is_optimal |
boolean |
Indicates if the class |
protocol_endpoint |
The class |
svm |
The SVM in which the vVol binding and its LUNs are located. Required in POST. |
vvol |
The class |
"href": "/api/resourcelink"
"count": 1,
"id": 1,
"is_optimal": 1,
"protocol_endpoint": {
"name": "/vol/volume1/lun1",
"svm": {
"name": "svm1",
"vvol": {
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4 |
The vVol binding was not found. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
_links |
name |
string |
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH. |
uuid |
string |
The unique identifier of the LUN. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
vvol
The class vvol LUN in the vVol binding. Required in POST.
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
