REST API reference
Retrieve a vVol binding
Retrieves a vVol binding to view the association between a virtual volume and its respective storage resources.
HTTP method and endpoint
GET /protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
Introduced in
ONTAP 9.10
  • lun bind show
string
path
True
The unique identifier of the class protocol_endpoint LUN.
vvol.uuid
string
path
True
The unique identifier of the class vvol LUN.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
count
integer
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
id
integer
The ONTAP internal identifier assigned to the vVol binding. The bind identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
This property was included in early releases of the REST API for vVols and is maintained for backward compatability. See the secondary_id property, which replaces id.
  • example: 1
  • readOnly: 1
  • x-ntap-deprecated: 9.13.1
  • Introduced in: 9.10
  • x-nullable: true
is_optimal
boolean
Indicates if the class protocol_endpoint LUN and the class vvol LUN are on the same cluster node.
protocol_endpoint
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
secondary_id
string
The identifier assigned to the vVol binding, known as the secondary LUN ID. The identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
The format for a secondary LUN ID is 16 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
svm
The SVM in which the vVol binding and its LUNs are located. Required in POST.
vvol
vvol
The class vvol LUN in the vVol binding. Required in POST.
      "href": "/api/resourcelink"
  "count": 1,
  "id": 1,
  "is_optimal": 1,
  "protocol_endpoint": {
    "name": "/vol/volume1/lun1",
  "secondary_id": "0000D20000010000h",
  "svm": {
    "name": "svm1",
  "vvol": {
Status: Default
ONTAP Error Response Codes
Error Code Description
4
The vVol binding was not found.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
protocol_endpoint
_links
_links
name
string
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
uuid
string
The unique identifier of the LUN.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
vvol
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
