REST API reference
Retrieve a specific SnapMirror policy
Retrieves details of a specific SnapMirror policy. This is useful for understanding the configuration and rules applied to data replication processes.
HTTP method and endpoint
GET /snapmirror/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific SnapMirror policy.
Example
GET "/api/snapmirror/policies/567aaac0-f863-11e8-a666-0050568e12c2"
uuid
string
path
True
Policy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
archive
archive
Archive information for the objects in an object store SnapMirror relationship. This property is applicable only for "async" policies with "create_snapshot_on_source" set to "false".
comment
string
Comment associated with the policy.
copy_all_source_snapshots
boolean
Specifies that all the source Snapshot copies (including the one created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
copy_latest_source_snapshot
boolean
Specifies that the latest source Snapshot copy (created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies whether a new Snapshot copy should be created on the source at the beginning of an update or resync operation. This is applicable only to async policies. Property can only be set to 'false'.
identity_preservation
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
Name of the policy.
network_compression_enabled
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Rules for Snapshot copy retention.
rpo
integer
Specifies the duration of time for which a change to be propogated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propogation. This is supported for policies of type 'continuous'.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
snapshot_lock_mode
string
Specifies the lock mode of the Snapshot copies stored in the object store. This property is applicable only to policies of type "async" with "create_snapshot_on_source" set to "false". When set to enterprise or compliance, the policy can be associated only with SnapMirror relationships where the source endpoint is a FlexVol volume and the destination endpoint is an object store. When set to compliance, no users can delete a Snapshot copy until the retention period has expired. When set to enterprise, users that have special permissions can delete a Snapshot copy before the retention period has expired.
svm
svm
sync_common_snapshot_schedule
Schedule used to create common Snapshot copies for synchronous relationships.
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror.
type
string
uuid
string
      "href": "/api/resourcelink"
  "comment": "string",
  "copy_all_source_snapshots": 1,
  "copy_latest_source_snapshot": 1,
  "create_snapshot_on_source": "",
  "identity_preservation": "string",
  "name": "Asynchronous",
  "retention": [
      "count": 7,
      "creation_schedule": {
        "name": "weekly",
      "label": "hourly",
      "period": "P30D",
      "prefix": "string"
  "rpo": 0,
  "scope": "string",
  "snapshot_lock_mode": "string",
  "svm": {
    "name": "svm1",
  "sync_common_snapshot_schedule": {
    "name": "weekly",
  "sync_type": "string",
  "throttle": 0,
  "transfer_schedule": {
    "name": "weekly",
  "type": "string",
Status: Default
ONTAP Error Response codes
Error code Description
13303842
SnapMirror policy is not supported.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
archive
after_days
integer
Number of days after which the objects are archived. This is only applicable when "archive.enabled" is "true". If this property is not set when "archive.enabled" is "true", the default value is "0" and therefore archiving will be triggered instantly. The value range is 0..999. If the value is set to "0", the latest snapshot copy will be archived. The value of after_days cannot be changed from "0" if any FlexVol SnapMirror relationship is associated with the policy.
enabled
boolean
When set to "true", the objects are archived. When set to "false", the objects are not archived.
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention. Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
SnapMirror policy rule for retention.
count
integer
Number of Snapshot copies to be kept for retention.
creation_schedule
creation_schedule
label
string
Snapshot copy label
period
string
Specifies the duration for which the Snapshot copies in the object store are locked. This property is valid only when the property 'snapshot_lock_mode' in the policy is set to enterprise or compliance. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, or days. A period specified for years, months, or days is represented in the ISO-8601 format as "PY", "PM", or "PD" respectively. For example, "P10Y" represents a duration of 10 years. The period string must contain only a single time element, that is, either years, months, or days. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Years, if specified, must be less than or equal to 100. Months, if specified, must be less than or equal to 1200. Days, if specified, must be between and including 30 and 36500.
prefix
string
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
