REST API reference
Retrieve a specific SnapMirror policy
Retrieves details about a specific SnapMirror policy, helping you manage and configure your data replication settings effectively.
HTTP method and endpoint
GET /snapmirror/policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific SnapMirror policy.
Example
GET "/api/snapmirror/policies/567aaac0-f863-11e8-a666-0050568e12c2"
uuid
string
path
True
SnapMirror policy UUID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
Comment associated with the policy.
copy_all_source_snapshots
boolean
Specifies that all the source snapshots (including the one created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
copy_latest_source_snapshot
boolean
Specifies that the latest source snapshot (created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
create_snapshot_on_source
boolean
Specifies whether a new snapshot should be created on the source at the beginning of an update or resync operation. This is applicable only to async policies. Property can only be set to 'false'.
identity_preservation
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
Name of the policy.
network_compression_enabled
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Rules for snapshot retention.
rpo
integer
Specifies the duration of time for which a change to be propagated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propagation. This is supported for policies of type 'continuous'.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
sync_common_snapshot_schedule
Schedule used to create common snapshots for synchronous relationships.
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror.
type
string
uuid
string
Unique identifier of the SnapMirror policy.
      "href": "/api/resourcelink"
  "comment": "string",
  "copy_all_source_snapshots": 1,
  "copy_latest_source_snapshot": 1,
  "create_snapshot_on_source": "",
  "identity_preservation": "string",
  "name": "Asynchronous",
  "retention": [
      "count": 7,
      "creation_schedule": {
        "name": "weekly",
      "label": "hourly",
      "period": "P30D",
      "prefix": "string",
      "preserve": 1,
      "warn": 4
  "rpo": 0,
  "scope": "string",
  "svm": {
    "name": "svm1",
  "sync_common_snapshot_schedule": {
    "name": "weekly",
  "sync_type": "string",
  "throttle": 0,
  "transfer_schedule": {
    "name": "weekly",
  "type": "string",
Status: Default
ONTAP Error Response codes
Error code Description
13303842
SnapMirror policy is not supported.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
creation_schedule
Schedule used to create snapshots on the destination for long term retention. Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
SnapMirror policy rule for retention.
count
integer
Number of snapshots to be kept for retention. Maximum value will differ based on type of relationship and scaling factor.
creation_schedule
creation_schedule
label
string
Snapshot label
period
string
Specifies the duration for which the snapshots are locked. The retention period value represents a duration and must be in the ISO-8601 duration format. Years, months, days, hours, minutes, and seconds are represented as "PY","PM","PD","PTH","PTM" and "PTS". Value "infinite" is also a valid input for Flexvol volumes and FlexGroup volumes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. The range of supported retention period values is between 1 second to infinite.
prefix
string
Specifies the prefix for the snapshot name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
preserve
boolean
Specifies the behavior when the snapshot retention count is reached on the SnapMirror destination for the rule. The default value is false, which means that the oldest snapshot is deleted to make room for new ones but only if the number of snapshots has exceeded the retention count specified in the 'count' property. When set to true and where the snapshots have reached the retention count, an incremental SnapMirror transfer will fail or if the rule has a schedule, snapshots will be no longer be created on the SnapMirror destination.
warn
integer
Specifies the warning threshold count for the rule. The default value is zero. When set to a value greater than zero, an event is generated after the number of snapshots (for the particular rule) retained on a SnapMirror destination reaches the specified warning limit. The preserve property for the rule must be true in order to set the warn property to a value greater than zero.
svm
_links
_links
name
string
uuid
string
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
