REST API reference
Retrieve SnapMirror async and sync policy types
Retrieves SnapMirror policies of both async and sync types, which helps you understand the current configurations for data replication.
HTTP method and endpoint
GET /snapmirror/policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves SnapMirror policies of type "async" and "sync".
  • snapmirror policy show
Example
The following example shows how to retrieve a collection of SnapMirror policies.
GET "/api/snapmirror/policies"
name
string
query
False
Filter by name
comment
string
query
False
Filter by comment
sync_type
string
query
False
Filter by sync_type
throttle
integer
query
False
Filter by throttle
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
scope
string
query
False
Filter by scope
network_compression_enabled
boolean
query
False
Filter by network_compression_enabled
archive.after_days
integer
query
False
Filter by archive.after_days
  • Introduced in: 9.11
archive.enabled
boolean
query
False
Filter by archive.enabled
identity_preservation
string
query
False
Filter by identity_preservation
uuid
string
query
False
Filter by uuid
create_snapshot_on_source
boolean
query
False
Filter by create_snapshot_on_source
type
string
query
False
Filter by type
rpo
integer
query
False
Filter by rpo
  • Introduced in: 9.10
copy_all_source_snapshots
boolean
query
False
Filter by copy_all_source_snapshots
retention.count
integer
query
False
Filter by retention.count
retention.creation_schedule.uuid
string
query
False
Filter by retention.creation_schedule.uuid
retention.creation_schedule.name
string
query
False
Filter by retention.creation_schedule.name
retention.prefix
string
query
False
Filter by retention.prefix
retention.period
string
query
False
Filter by retention.period
retention.label
string
query
False
Filter by retention.label
snapshot_lock_mode
string
query
False
Filter by snapshot_lock_mode
transfer_schedule.uuid
string
query
False
Filter by transfer_schedule.uuid
transfer_schedule.name
string
query
False
Filter by transfer_schedule.name
copy_latest_source_snapshot
boolean
query
False
Filter by copy_latest_source_snapshot
sync_common_snapshot_schedule.uuid
string
query
False
Filter by sync_common_snapshot_schedule.uuid
sync_common_snapshot_schedule.name
string
query
False
Filter by sync_common_snapshot_schedule.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapmirror_policy]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "copy_all_source_snapshots": 1,
      "copy_latest_source_snapshot": 1,
      "create_snapshot_on_source": "",
      "identity_preservation": "string",
      "name": "Asynchronous",
      "retention": [
          "count": 7,
          "creation_schedule": {
            "name": "weekly",
          "label": "hourly",
          "period": "P30D",
          "prefix": "string"
      "rpo": 0,
      "scope": "string",
      "snapshot_lock_mode": "string",
      "svm": {
        "name": "svm1",
      "sync_common_snapshot_schedule": {
        "name": "weekly",
      "sync_type": "string",
      "throttle": 0,
      "transfer_schedule": {
        "name": "weekly",
      "type": "string",
Status: Default
ONTAP Error Response codes
Error code Description
13303842
SnapMirror policy is not supported.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
archive
Archive information for the objects in an object store SnapMirror relationship. This property is applicable only for "async" policies with "create_snapshot_on_source" set to "false".
after_days
integer
Number of days after which the objects are archived. This is only applicable when "archive.enabled" is "true". If this property is not set when "archive.enabled" is "true", the default value is "0" and therefore archiving will be triggered instantly. The value range is 0..999. If the value is set to "0", the latest snapshot copy will be archived. The value of after_days cannot be changed from "0" if any FlexVol SnapMirror relationship is associated with the policy.
enabled
boolean
When set to "true", the objects are archived. When set to "false", the objects are not archived.
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention. Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy_rule
SnapMirror policy rule for retention.
count
integer
Number of Snapshot copies to be kept for retention.
creation_schedule
creation_schedule
label
string
Snapshot copy label
period
string
Specifies the duration for which the Snapshot copies in the object store are locked. This property is valid only when the property 'snapshot_lock_mode' in the policy is set to enterprise or compliance. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, or days. A period specified for years, months, or days is represented in the ISO-8601 format as "PY", "PM", or "PD" respectively. For example, "P10Y" represents a duration of 10 years. The period string must contain only a single time element, that is, either years, months, or days. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Years, if specified, must be less than or equal to 100. Months, if specified, must be less than or equal to 1200. Days, if specified, must be between and including 30 and 36500.
prefix
string
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
Schedule used to create common Snapshot copies for synchronous relationships.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async", "sync" or "continuous". The policy type "async" can be associated with a SnapMirror relationship that has either the FlexVol volume or FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync" or "automated_failover". If the "sync_type" is "sync" then a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync" then a write success is returned to the client after writing the data to the both source and destination endpoints. If the "sync_type" is "automated_failover" then the policy can be associated with a SnapMirror relationship that has Consistency Group as the endpoint. Use the "sync" policy with "sync_type" as "automated_failover" to establish SnapMirror relationships for business continuity usecases. SnapMirror relationships with policy type as "sync" and "sync_type" as "automated_failover" can be monitored by the Mediator, if configured. In case the source Consistency Group endpoint is not reachable, the Mediator may trigger a failover to the destination Consistency Group endpoint. A policy of type "continuous" can be associated with SnapMirror relationships that have either ONTAP S3 buckets or NON-ONTAP object stores as endpoints. This type of policy is used for FabricLink owned targets.
_links
_links
archive
archive
comment
string
Comment associated with the policy.
boolean
Specifies that all the source Snapshot copies (including the one created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies that the latest source Snapshot copy (created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies whether a new Snapshot copy should be created on the source at the beginning of an update or resync operation. This is applicable only to async policies. Property can only be set to 'false'.
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
Name of the policy.
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Rules for Snapshot copy retention.
rpo
integer
Specifies the duration of time for which a change to be propogated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propogation. This is supported for policies of type 'continuous'.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
snapshot_lock_mode
string
Specifies the lock mode of the Snapshot copies stored in the object store. This property is applicable only to policies of type "async" with "create_snapshot_on_source" set to "false". When set to enterprise or compliance, the policy can be associated only with SnapMirror relationships where the source endpoint is a FlexVol volume and the destination endpoint is an object store. When set to compliance, no users can delete a Snapshot copy until the retention period has expired. When set to enterprise, users that have special permissions can delete a Snapshot copy before the retention period has expired.
svm
svm
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
type
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
