REST API reference
Retrieve SnapMirror async and sync policy types
Retrieves SnapMirror policies of type "async" and "sync" to manage data replication configurations effectively.
HTTP method and endpoint
GET /snapmirror/policies
Introduced in
ONTAP 9.6
  • snapmirror policy show
Example
The following example shows how to retrieve a collection of SnapMirror policies.
GET "/api/snapmirror/policies"
name
string
query
False
Filter by name
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
throttle
integer
query
False
Filter by throttle
copy_latest_source_snapshot
boolean
query
False
Filter by copy_latest_source_snapshot
  • Introduced in: 9.11
comment
string
query
False
Filter by comment
transfer_schedule.uuid
string
query
False
Filter by transfer_schedule.uuid
transfer_schedule.name
string
query
False
Filter by transfer_schedule.name
network_compression_enabled
boolean
query
False
Filter by network_compression_enabled
type
string
query
False
Filter by type
create_snapshot_on_source
boolean
query
False
Filter by create_snapshot_on_source
sync_common_snapshot_schedule.uuid
string
query
False
Filter by sync_common_snapshot_schedule.uuid
sync_common_snapshot_schedule.name
string
query
False
Filter by sync_common_snapshot_schedule.name
rpo
integer
query
False
Filter by rpo
  • Introduced in: 9.10
copy_all_source_snapshots
boolean
query
False
Filter by copy_all_source_snapshots
sync_type
string
query
False
Filter by sync_type
scope
string
query
False
Filter by scope
uuid
string
query
False
Filter by uuid
retention.prefix
string
query
False
Filter by retention.prefix
retention.period
string
query
False
Filter by retention.period
retention.count
string
query
False
Filter by retention.count
retention.preserve
boolean
query
False
Filter by retention.preserve
  • Introduced in: 9.13
retention.label
string
query
False
Filter by retention.label
retention.creation_schedule.uuid
string
query
False
Filter by retention.creation_schedule.uuid
retention.creation_schedule.name
string
query
False
Filter by retention.creation_schedule.name
retention.warn
integer
query
False
Filter by retention.warn
identity_preservation
string
query
False
Filter by identity_preservation
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapmirror_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "copy_all_source_snapshots": 1,
      "copy_latest_source_snapshot": 1,
      "create_snapshot_on_source": "",
      "identity_preservation": "string",
      "name": "Asynchronous",
      "retention": [
          "count": "7",
          "creation_schedule": {
            "name": "weekly",
          "label": "hourly",
          "period": "P30D",
          "prefix": "string",
          "preserve": 1,
          "warn": 4
      "rpo": 0,
      "scope": "string",
      "svm": {
        "name": "svm1",
      "sync_common_snapshot_schedule": {
        "name": "weekly",
      "sync_type": "string",
      "throttle": 0,
      "transfer_schedule": {
        "name": "weekly",
      "type": "string",
Status: Default
ONTAP Error Response codes
Error code Description
13303842
SnapMirror policy is not supported.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
creation_schedule
Schedule used to create snapshots on the destination for long term retention. Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy_rule
SnapMirror policy rule for retention.
count
string
Number of snapshots to be kept for retention. Maximum value will differ based on type of relationship and scaling factor.
creation_schedule
creation_schedule
label
string
Snapshot label
period
string
Specifies the duration for which the snapshots are locked. The retention period value represents a duration and must be in the ISO-8601 duration format. Years, months, days, hours, minutes, and seconds are represented as "PY","PM","PD","PTH","PTM" and "PTS". Value "infinite" is also a valid input for Flexvol volumes and FlexGroup volumes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. The range of supported retention period values is between 1 second to infinite.
prefix
string
Specifies the prefix for the snapshot name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
preserve
boolean
Specifies the behavior when the snapshot retention count is reached on the SnapMirror destination for the rule. The default value is false, which means that the oldest snapshot is deleted to make room for new ones but only if the number of snapshots has exceeded the retention count specified in the 'count' property. When set to true and where the snapshots have reached the retention count, an incremental SnapMirror transfer will fail or if the rule has a schedule, snapshots will be no longer be created on the SnapMirror destination.
warn
integer
Specifies the warning threshold count for the rule. The default value is zero. When set to a value greater than zero, an event is generated after the number of snapshots (for the particular rule) retained on a SnapMirror destination reaches the specified warning limit. The preserve property for the rule must be true in order to set the warn property to a value greater than zero.
svm
_links
_links
name
string
uuid
string
Schedule used to create common snapshots for synchronous relationships.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
The schedule used to update asynchronous relationships. Only cron schedules are supported for SnapMirror.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy
SnapMirror policy information. SnapMirror policy can either be of type "async", "sync" or "continuous". The policy type "async" can be associated with a SnapMirror relationship that has either a FlexVol volume, FlexGroup volume or SVM as the endpoint. The policy type "sync" along with "sync_type" as "sync" or "strict_sync" can be associated with a SnapMirror relationship that has a FlexVol volume as the endpoint. The policy type "sync" can have a "sync_type" of either "sync", "strict_sync", "automated_failover" or "automated_failover_duplex". If the "sync_type" is "sync", a write success is returned to the client after writing the data to the source endpoint and before writing the data to the destination endpoint. If the "sync_type" is "strict_sync", a write success is returned to the client after writing the data to both source and destination endpoints. If the "sync_type" is "automated_failover", the policy can be associated with a SnapMirror active sync relationship that has a consistency group as the endpoint and provides asymmetric active active access to the two storage copies. If the "sync_type" is "automated_failover_duplex", the policy can be associated with a SnapMirror active sync relationship that has a consistency group as the endpoint and provides symmetric active active access to the two storage copies. Use the "sync" policy with "sync_type" as "automated_failover" or "automated_failover_duplex" to establish SnapMirror active sync relationships for business continuity use cases. SnapMirror relationships with policy types as "sync" and "sync_type" as "automated_failover" or "automated_failover_duplex" can be monitored by the Mediator, if configured. If the source Consistency Group endpoint is not reachable, the Mediator might trigger a failover to the destination consistency group endpoint. A policy type of "continuous" can be associated with SnapMirror relationships that have either ONTAP S3 buckets or non-ONTAP object stores as endpoints. This type of policy is used for FabricLink owned targets.
_links
_links
comment
string
Comment associated with the policy.
boolean
Specifies that all the source snapshots (including the one created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies that the latest source snapshot (created by SnapMirror before the transfer begins) should be copied to the destination on a transfer. "Retention" properties cannot be specified along with this property. This is applicable only to async policies. Property can only be set to 'true'.
boolean
Specifies whether a new snapshot should be created on the source at the beginning of an update or resync operation. This is applicable only to async policies. Property can only be set to 'false'.
string
Specifies which configuration of the source SVM is replicated to the destination SVM. This property is applicable only for SVM data protection with "async" policy type.
name
string
Name of the policy.
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to the policies of type "async".
retention
array[snapmirror_policy_rule]
Rules for snapshot retention.
rpo
integer
Specifies the duration of time for which a change to be propagated to a mirror should be delayed, in seconds. This is an intentional propagation delay between mirrors and is configurable down to zero, which means an immediate propagation. This is supported for policies of type 'continuous'.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
type
string
uuid
string
Unique identifier of the SnapMirror policy.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
