REST API reference
Retrieve the cloud store for an aggregate
Retrieves the cloud store associated with a specific aggregate to access information about the configured cloud target.
HTTP method and endpoint
GET /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the cloud store for the aggregate using the specified cloud target UUID.
  • storage aggregate object-store show
aggregate.uuid
string
path
True
Aggregate UUID
target.uuid
string
path
True
Cloud target UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
aggregate
aggregate
Aggregate
availability
string
Availability of the object store.
mirror_degraded
boolean
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.
primary
boolean
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.
target
target
Cloud target
unavailable_reason
unavailable_reason
unreclaimed_space_threshold
integer
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.
used
integer
The amount of object space used. Calculated every 5 minutes and cached.
      "href": "/api/resourcelink"
  "aggregate": {
    "name": "aggr1"
  "availability": "string",
  "target": {
    "name": "target1",
  "unavailable_reason": {
    "message": "string"
  "unreclaimed_space_threshold": 20,
  "used": 0
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
aggregate
Aggregate
name
string
target
Cloud target
_links
_links
name
string
uuid
string
unavailable_reason
message
string
Indicates why the object store is unavailable.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
