Retrieve the cloud store for an aggregate
GET /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Introduced In: 9.6
Retrieves the cloud store for the aggregate using the specified cloud target UUID.
Related ONTAP commands
storage aggregate object-store show
aggregate.uuid  |
string  |
path  |
True  |
Aggregate UUID  |
target.uuid  |
string  |
path  |
True  |
Cloud target UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
aggregate  |
Aggregate  |
availability  |
string  |
Availability of the object store.  |
mirror_degraded  |
boolean  |
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.  |
primary  |
boolean  |
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.  |
target  |
Cloud target  |
unavailable_reason  |
unreclaimed_space_threshold  |
integer  |
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.  |
used  |
integer  |
The amount of object space used. Calculated every 5 minutes and cached.  |
      "href": "/api/resourcelink"
  "aggregate": {
    "name": "aggr1"
  "availability": "string",
  "target": {
    "name": "target1",
  "unavailable_reason": {
    "message": "string"
  "unreclaimed_space_threshold": 20,
  "used": 0
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
aggregate
Aggregate
name  |
string  |
target
Cloud target
_links  |
name  |
string  |
uuid  |
string  |
message  |
string  |
Indicates why the object store is unavailable.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
