Retrieve a specific bridge
GET /storage/bridges/{wwn}
Introduced In: 9.9
Retrieves a specific bridge
Related ONTAP commands
storage bridge show
Learn more
wwn  |
string  |
path  |
True  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
chassis_throughput_state  |
string  |
Chassis throughput status  |
dram_single_bit_error_count  |
integer  |
errors  |
array[errors]  |
fc_ports  |
array[fc_ports]  |
firmware_version  |
string  |
Bridge firmware version  |
ip_address  |
string  |
IP Address  |
last_reboot  |
managed_by  |
string  |
model  |
string  |
Bridge model  |
monitoring_enabled  |
boolean  |
Indicates whether monitoring is enabled for the bridge.  |
name  |
string  |
Bridge name  |
paths  |
array[paths]  |
power_supply_units  |
array[power_supply_units]  |
sas_ports  |
array[sas_ports]  |
security_enabled  |
boolean  |
Indicates whether security is enabled for the bridge.  |
serial_number  |
string  |
Bridge serial number  |
state  |
string  |
Bridge state  |
symbolic_name  |
string  |
Bridge symbolic name  |
temperature_sensor  |
vendor  |
string  |
Bridge vendor  |
wwn  |
string  |
Bridge world wide name  |
  "chassis_throughput_state": "ok",
  "errors": [
      "component": {
        "name": "string",
        "unique_id": "string"
      "reason": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "target": "uuid"
      "severity": "string",
      "type": "string"
  "fc_ports": [
      "configured_data_rate": "0",
      "connection_mode": "string",
      "data_rate_capability": "2",
      "negotiated_data_rate": "0",
      "peer_wwn": "200650eb1a238892",
      "sfp": {
        "part_number": "string",
        "serial_number": "string",
        "vendor": "string"
      "state": "string",
      "wwn": "2100001086a54100"
  "firmware_version": "4.10 007A",
  "ip_address": "string",
  "last_reboot": {
    "reason": {
      "arguments": [
          "code": "string",
          "message": "string"
      "code": "4",
      "target": "uuid"
    "time": "2020-12-09T00:47:58-05:00"
  "managed_by": "string",
  "model": "FibreBridge6500N",
  "name": "ATTO_FibreBridge6500N_1",
  "paths": [
      "name": "2c",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "source_port": {
        "id": "100050eb1a238892",
        "name": "rtp-fc03-41kk11:1"
      "target_port": {
        "name": "rtp-fc03-41kk11:6",
  "power_supply_units": [
      "name": "string",
      "state": "string"
  "sas_ports": [
      "cable": {
        "technology": "string",
        "vendor": "string"
      "data_rate_capability": "0",
      "phy_1": {
        "state": "string"
      "phy_2": {
        "state": "string"
      "phy_3": {
        "state": "string"
      "phy_4": {
        "state": "string"
      "state": "string",
  "serial_number": "FB7600N100004",
  "state": "string",
  "symbolic_name": "rtp-fcsas03-41kk11",
  "temperature_sensor": {
    "name": "Chassis temperature sensor",
    "state": "string"
  "vendor": "atto",
  "wwn": "2000001086600476"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
component
id  |
integer  |
Bridge error component ID  |
name  |
string  |
Bridge error component name  |
unique_id  |
string  |
Bridge error component unique ID  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
errors
component  |
reason  |
severity  |
string  |
Bridge error severity  |
type  |
string  |
Bridge error type  |
sfp
data_rate_capability  |
number  |
Bridge FC port SFP data rate capability, in Gbps  |
part_number  |
string  |
serial_number  |
string  |
Bridge FC port SFP serial number  |
vendor  |
string  |
Bridge FC port SFP vendor  |
fc_ports
configured_data_rate  |
number  |
Bridge FC port configured data rate, in Gbps  |
connection_mode  |
string  |
Bridge FC port configured connection mode  |
number  |
Bridge FC port data rate capability, in Gbps  |
enabled  |
boolean  |
Indicates whether the bridge FC port is enabled.  |
id  |
integer  |
Bridge FC port index  |
negotiated_data_rate  |
number  |
Bridge FC port negotiated data rate, in Gbps  |
peer_wwn  |
string  |
Bridge FC port peer port world wide name  |
sfp  |
state  |
string  |
Bridge FC port state  |
wwn  |
string  |
Bridge FC port world wide name  |
error
The error message and code explaining why the bridge rebooted.
arguments  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
last_reboot
reason  |
The error message and code explaining why the bridge rebooted.  |
time  |
string  |
href  |
string  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
source_port
id  |
string  |
Initiator side switch port id  |
name  |
string  |
Initiator side switch port name  |
target_port
id  |
string  |
Target side switch port id  |
name  |
string  |
Target side switch port name  |
wwn  |
string  |
Target side switch port world wide name  |
paths
name  |
string  |
node  |
source_port  |
target_port  |
power_supply_units
name  |
string  |
Power supply unit name  |
state  |
string  |
Power supply unit state  |
cable
part_number  |
string  |
Bridge cable part number  |
serial_number  |
string  |
Bridge cable serial number  |
technology  |
string  |
Bridge cable type  |
vendor  |
string  |
Bridge cable vendor  |
phy_1
state  |
string  |
Bridge SAS port PHY1 state  |
phy_2
state  |
string  |
Bridge SAS port PHY2 state  |
phy_3
state  |
string  |
Bridge SAS port PHY3 state  |
phy_4
state  |
string  |
Bridge SAS port PHY4 state  |
sas_ports
cable  |
number  |
Bridge SAS port data rate capability, in Gbps  |
enabled  |
boolean  |
Indicates whether a bridge SAS port is enabled.  |
id  |
integer  |
Bridge SAS port index  |
number  |
Bridge SAS port negotiated data rate, in Gbps  |
phy_1  |
phy_2  |
phy_3  |
phy_4  |
state  |
string  |
Bridge SAS port state  |
wwn  |
string  |
Bridge SAS port world wide name  |
temperature_sensor
maximum  |
integer  |
Maximum safe operating temperature, in degrees Celsius.  |
minimum  |
integer  |
Minimum safe operating temperature, in degrees Celsius.  |
name  |
string  |
Temperature sensor name  |
reading  |
integer  |
Chassis temperature sensor reading, in degrees Celsius.  |
state  |
string  |
