REST API reference
Retrieve a specific bridge
Retrieves detailed information about a specific bridge, helping you manage and monitor bridge configurations effectively.
HTTP method and endpoint
GET /storage/bridges/{wwn}
Introduced in
ONTAP 9.9
Usage notes
Retrieves a specific bridge
  • storage bridge show
wwn
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
chassis_throughput_state
string
Chassis throughput status
dram_single_bit_error_count
integer
errors
array[errors]
fc_ports
array[fc_ports]
firmware_version
string
Bridge firmware version
ip_address
string
IP Address
last_reboot
last_reboot
managed_by
string
model
string
Bridge model
monitoring_enabled
boolean
Indicates whether monitoring is enabled for the bridge.
name
string
Bridge name
paths
array[paths]
power_supply_units
array[power_supply_units]
sas_ports
array[sas_ports]
security_enabled
boolean
Indicates whether security is enabled for the bridge.
serial_number
string
Bridge serial number
state
string
Bridge state
symbolic_name
string
Bridge symbolic name
temperature_sensor
temperature_sensor
vendor
string
Bridge vendor
wwn
string
Bridge world wide name
  "chassis_throughput_state": "ok",
  "errors": [
      "component": {
        "name": "string",
        "unique_id": "string"
      "reason": {
        "code": "string",
        "message": "string"
      "severity": "string",
      "type": "string"
  "fc_ports": [
      "configured_data_rate": "0",
      "connection_mode": "string",
      "data_rate_capability": "2",
      "negotiated_data_rate": "0",
      "peer_wwn": "200650eb1a238892",
      "sfp": {
        "part_number": "string",
        "serial_number": "string",
        "vendor": "string"
      "state": "string",
      "wwn": "2100001086a54100"
  "firmware_version": "4.10 007A",
  "ip_address": "string",
  "last_reboot": {
    "reason": {
      "code": "39321683",
      "message": "FirmwareRestart Command"
    "time": "2020-12-09T00:47:58-05:00"
  "managed_by": "string",
  "model": "FibreBridge6500N",
  "name": "ATTO_FibreBridge6500N_1",
  "paths": [
      "name": "2c",
      "node": {
            "href": "/api/resourcelink"
        "name": "node1",
      "source_port": {
        "id": "100050eb1a238892",
        "name": "rtp-fc03-41kk11:1"
      "target_port": {
        "name": "rtp-fc03-41kk11:6",
  "power_supply_units": [
      "name": "string",
      "state": "string"
  "sas_ports": [
      "cable": {
        "technology": "string",
        "vendor": "string"
      "data_rate_capability": "0",
      "phy_1": {
        "state": "string"
      "phy_2": {
        "state": "string"
      "phy_3": {
        "state": "string"
      "phy_4": {
        "state": "string"
      "state": "string",
  "serial_number": "FB7600N100004",
  "state": "string",
  "symbolic_name": "rtp-fcsas03-41kk11",
  "temperature_sensor": {
    "name": "Chassis temperature sensor",
    "state": "string"
  "vendor": "atto",
  "wwn": "2000001086600476"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
component
id
integer
Bridge error component ID
name
string
Bridge error component name
unique_id
string
Bridge error component unique ID
reason
code
string
message
string
errors
component
component
reason
reason
severity
string
Bridge error severity
type
string
Bridge error type
sfp
number
Bridge FC port SFP data rate capability, in Gbps
part_number
string
serial_number
string
Bridge FC port SFP serial number
vendor
string
Bridge FC port SFP vendor
fc_ports
number
Bridge FC port configured data rate, in Gbps
connection_mode
string
Bridge FC port configured connection mode
number
Bridge FC port data rate capability, in Gbps
enabled
boolean
Indicates whether the bridge FC port is enabled.
id
integer
Bridge FC port index
number
Bridge FC port negotiated data rate, in Gbps
peer_wwn
string
Bridge FC port peer port world wide name
sfp
sfp
state
string
Bridge FC port state
wwn
string
Bridge FC port world wide name
reason
code
string
This field provides the error code explaining why did the bridge reboot.
message
string
This field provides the error message explaining why did the bridge reboot.
last_reboot
reason
reason
time
string
string
self
node
_links
_links
name
string
uuid
string
source_port
id
string
Initiator side switch port id
name
string
Initiator side switch port name
target_port
id
string
Target side switch port id
name
string
Target side switch port name
wwn
string
Target side switch port world wide name
paths
name
string
node
node
source_port
source_port
target_port
target_port
power_supply_units
name
string
Power supply unit name
state
string
Power supply unit state
cable
part_number
string
Bridge cable part number
serial_number
string
Bridge cable serial number
technology
string
Bridge cable type
vendor
string
Bridge cable vendor
phy_1
state
string
Bridge SAS port PHY1 state
phy_2
state
string
Bridge SAS port PHY2 state
phy_3
state
string
Bridge SAS port PHY3 state
phy_4
state
string
Bridge SAS port PHY4 state
sas_ports
cable
cable
number
Bridge SAS port data rate capability, in Gbps
enabled
boolean
Indicates whether a bridge SAS port is enabled.
id
integer
Bridge SAS port index
number
Bridge SAS port negotiated data rate, in Gbps
phy_1
phy_1
phy_2
phy_2
phy_3
phy_3
phy_4
phy_4
state
string
Bridge SAS port state
wwn
string
Bridge SAS port world wide name
temperature_sensor
maximum
integer
Maximum safe operating temperature, in degrees Celsius.
minimum
integer
Minimum safe operating temperature, in degrees Celsius.
name
string
Temperature sensor name
reading
integer
Chassis temperature sensor reading, in degrees Celsius.
state
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
