REST API reference
Retrieve a specific quota report record
Retrieves detailed information about a specific quota report record, which helps you monitor and manage storage usage efficiently.
HTTP method and endpoint
GET /storage/quota/reports/{volume.uuid}/{index}
Introduced in
ONTAP 9.6
Usage notes
Retrieves a specific quota report record.
  • quota report
volume.uuid
string
path
True
Volume UUID
index
integer
path
True
Quota report index
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
files
files
group
group
This parameter specifies the target group associated with the given quota report record. This parameter is available for group quota records and is not available for user or tree quota records. The target group is identified by a UNIX group name and UNIX group identifer.
index
integer
Index that identifies a unique quota record. Valid in URL.
qtree
qtree
This parameter specifies the target qtree associated with the user, group, or tree record. For a user/group quota policy rule at volume level, this parameter is not valid. For a default tree quota policy rule, this parameter is specified as "" or "*". For a tree quota policy rule at qtree level, this parameter specifies a qtree name and a qtree identifier.
space
space
specifier
string
Quota specifier
svm
svm
type
string
Quota type associated with the quota record.
users
array[users]
This parameter specifies the target user or users associated with the given quota report record. This parameter is available for user quota records and is not available for group or tree quota records. The target user or users are identified by a user name and user identifier. The user name can be a UNIX user name or a Windows user name, and the identifer can be a UNIX user identifier or a Windows security identifier.
volume
volume
      "href": "/api/resourcelink"
  "files": {
    "hard_limit": 0,
    "soft_limit": 0,
    "used": {
      "hard_limit_percent": 0,
      "soft_limit_percent": 0,
      "total": 0
  "group": {
    "id": "string",
    "name": "string"
  "index": 0,
  "qtree": {
    "id": 1,
    "name": "qt1"
  "space": {
    "hard_limit": 0,
    "soft_limit": 0,
    "used": {
      "total": 0
  "specifier": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
  "users": [
      "id": "string",
      "name": "string"
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
918235
A volume with UUID was not found.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
used
hard_limit_percent
integer
Total files used as a percentage of file hard limit
soft_limit_percent
integer
Total files used as a percentage of file soft limit
total
integer
Total files used
files
hard_limit
integer
File hard limit
soft_limit
integer
File soft limit
used
used
group
id
string
Quota target group ID
name
string
Quota target group name
qtree
_links
_links
id
integer
The unique identifier for a qtree.
name
string
The name of the qtree.
used
hard_limit_percent
integer
Total space used as a percentage of space hard limit
soft_limit_percent
integer
Total space used as a percentage of space soft limit
total
integer
Total space used
space
hard_limit
integer
Space hard limit in bytes
soft_limit
integer
Space soft limit in bytes
used
used
svm
_links
_links
name
string
The name of the SVM.
uuid
string
users
id
string
Quota target user ID
name
string
Quota target user name
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
