Retrieve a specific quota report record
Retrieves a specific quota report record to view detailed information about quota usage and limits for a particular resource. This is useful for monitoring and managing storage allocations efficiently.
HTTP method and endpoint
GET /storage/quota/reports/{volume.uuid}/{index}
Introduced in
ONTAP 9.6
Related ONTAP commands
quota report
volume.uuid |
string |
path |
True |
Volume UUID |
index |
integer |
path |
True |
Quota report index |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
files |
group |
This parameter specifies the target group associated with the given quota report record. This parameter is available for group quota records and is not available for user or tree quota records. The target group is identified by a UNIX group name and UNIX group identifer. |
index |
integer |
Index that identifies a unique quota record. Valid in URL. |
qtree |
This parameter specifies the target qtree associated with the user, group, or tree record. For a user/group quota policy rule at volume level, this parameter is not valid. For a default tree quota policy rule, this parameter is specified as "" or "*". For a tree quota policy rule at qtree level, this parameter specifies a qtree name and a qtree identifier. |
space |
specifier |
string |
Quota specifier |
svm |
type |
string |
Quota type associated with the quota record. |
users |
array[users] |
This parameter specifies the target user or users associated with the given quota report record. This parameter is available for user quota records and is not available for group or tree quota records. The target user or users are identified by a user name and user identifier. The user name can be a UNIX user name or a Windows user name, and the identifer can be a UNIX user identifier or a Windows security identifier. |
volume |
"href": "/api/resourcelink"
"files": {
"hard_limit": 0,
"soft_limit": 0,
"used": {
"hard_limit_percent": 0,
"soft_limit_percent": 0,
"total": 0
"group": {
"id": "string",
"name": "string"
"index": 0,
"qtree": {
"id": 1,
"name": "qt1"
"space": {
"hard_limit": 0,
"soft_limit": 0,
"used": {
"total": 0
"specifier": "string",
"svm": {
"name": "svm1",
"type": "string",
"users": [
"id": "string",
"name": "string"
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
918235 |
A volume with UUID was not found. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
used
hard_limit_percent |
integer |
Total files used as a percentage of file hard limit |
soft_limit_percent |
integer |
Total files used as a percentage of file soft limit |
total |
integer |
Total files used |
files
hard_limit |
integer |
File hard limit |
soft_limit |
integer |
File soft limit |
used |
group
id |
string |
Quota target group ID |
name |
string |
Quota target group name |
qtree
_links |
id |
integer |
The unique identifier for a qtree. |
name |
string |
The name of the qtree. |
used
integer |
Total space used as a percentage of space hard limit |
integer |
Total space used as a percentage of space soft limit |
total |
integer |
Total space used |
space
hard_limit |
integer |
Space hard limit in bytes |
soft_limit |
integer |
Space soft limit in bytes |
used |
svm
_links |
name |
string |
uuid |
string |
users
id |
string |
Quota target user ID |
name |
string |
Quota target user name |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
