REST API reference
Retrieve SVMs configured with audit log volumes
Retrieves a list of SVMs that have audit log volumes configured. Use this to review which SVMs are set up for audit logging purposes.
HTTP method and endpoint
GET /storage/snaplock/audit-logs
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of SVMs configured with audit log volumes.
  • snaplock log show
log_archive.path
string
query
False
Filter by log_archive.path
log_archive.base_name
string
query
False
Filter by log_archive.base_name
log_archive.expiry_time
string
query
False
Filter by log_archive.expiry_time
log_archive.size
integer
query
False
Filter by log_archive.size
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
log_files.path
string
query
False
Filter by log_files.path
log_files.base_name
string
query
False
Filter by log_files.base_name
log_files.expiry_time
string
query
False
Filter by log_files.expiry_time
log_files.size
integer
query
False
Filter by log_files.size
log_volume.retention_period
string
query
False
Filter by log_volume.retention_period
log_volume.volume.name
string
query
False
Filter by log_volume.volume.name
log_volume.volume.uuid
string
query
False
Filter by log_volume.volume.uuid
log_volume.max_log_size
integer
query
False
Filter by log_volume.max_log_size
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snaplock_log]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "log_archive": {
        "base_name": "string",
        "expiry_time": "2058-06-04T19:00:00Z",
        "path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
        "size": 20000
      "log_files": [
          "size": 20000
      "log_volume": {
        "max_log_size": 20971520,
        "retention_period": "P30M",
        "volume": {
          "name": "volume1",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
log_archive
_links
_links
archive
boolean
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files.
base_name
string
Base name of log file
expiry_time
string
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time.
path
string
Absolute path of the log file in the volume
size
integer
Size of the log file in bytes
snaplock_log_file
_links
_links
archive
boolean
base_name
string
expiry_time
string
path
string
size
integer
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_log_volume
_links
_links
max_log_size
integer
Maximum size of log file in bytes
retention_period
string
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. A duration in hours, minutes and seconds is represented by "PTH", "PTM", and "PTS" respectively. The period string must contain only a single time element i.e. either years, months, days, hours, minutes or seconds. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the string "infinite".
volume
volume
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snaplock_log
_links
_links
log_archive
log_archive
log_files
array[snaplock_log_file]
log_volume
snaplock_log_volume
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
