Retrieve SVMs configured with audit log volumes
Retrieves a list of SVMs that are configured with audit log volumes. This is useful for monitoring and managing your audit log configurations across different storage virtual machines.
HTTP method and endpoint
GET /storage/snaplock/audit-logs
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of SVMs configured with audit log volumes.
Related ONTAP commands
snaplock log show
Learn more
log_volume.max_log_size |
integer |
query |
False |
Filter by log_volume.max_log_size |
log_volume.retention_period |
string |
query |
False |
Filter by log_volume.retention_period |
log_volume.volume.uuid |
string |
query |
False |
Filter by log_volume.volume.uuid |
log_volume.volume.name |
string |
query |
False |
Filter by log_volume.volume.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
log_files.path |
string |
query |
False |
Filter by log_files.path |
log_files.base_name |
string |
query |
False |
Filter by log_files.base_name |
log_files.size |
integer |
query |
False |
Filter by log_files.size |
log_files.expiry_time |
string |
query |
False |
Filter by log_files.expiry_time |
log_archive.path |
string |
query |
False |
Filter by log_archive.path |
log_archive.base_name |
string |
query |
False |
Filter by log_archive.base_name |
log_archive.size |
integer |
query |
False |
Filter by log_archive.size |
log_archive.expiry_time |
string |
query |
False |
Filter by log_archive.expiry_time |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snaplock_log] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"log_archive": {
"base_name": "string",
"expiry_time": "2058-06-04T19:00:00Z",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": 20000
"log_files": [
"size": 20000
"log_volume": {
"max_log_size": 20971520,
"retention_period": "P30M",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
log_archive
_links |
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
snaplock_log_file
_links |
archive |
boolean |
base_name |
string |
expiry_time |
string |
path |
string |
size |
integer |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
snaplock_log_volume
_links |
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_log
_links |
log_archive |
log_files |
array[snaplock_log_file] |
log_volume |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
