Retrieve EBR operations
GET /storage/snaplock/event-retention/operations
Introduced In: 9.7
Retrieves a list of all EBR operations.
Related ONTAP commands
snaplock event-retention show
volume.uuid |
string |
query |
True |
Volume UUID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[ebr_operation] |
"next": {
"href": "/api/resourcelink"
"records": [
"id": 16842759,
"num_files_failed": 0,
"num_files_processed": 50,
"num_files_skipped": 2,
"num_inodes_ignored": 2,
"path": "/dir1/file",
"policy": {
"name": "string",
"retention_period": "P30M",
"svm": {
"name": "svm1",
"state": "completed",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
policy
_links |
name |
string |
Specifies the EBR policy name |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
ebr_operation
_links |
id |
integer |
Operation ID |
num_files_failed |
integer |
Specifies the number of files on which the application of EBR policy failed. |
num_files_processed |
integer |
Specifies the number of files on which EBR policy was applied successfully. |
num_files_skipped |
integer |
Specifies the number of files on which the application of EBR policy was skipped. |
num_inodes_ignored |
integer |
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files. |
path |
string |
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory. |
policy |
state |
string |
Specifies the operation status of an EBR operation. |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
