Retrieve EBR operations
GET /storage/snaplock/event-retention/operations
Introduced In: 9.7
Retrieves a list of all EBR operations.
Related ONTAP commands
snaplock event-retention show
volume.uuid  |
string  |
query  |
False  |
Volume UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[ebr_operation]  |
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "id": 16842759,
      "num_files_failed": 0,
      "num_files_processed": 50,
      "num_files_skipped": 2,
      "num_inodes_ignored": 2,
      "path": "/dir1/file",
      "policy": {
        "name": "string",
        "retention_period": "P30M"
      "state": "completed",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090242  |
Only a user with the security login role "vsadmin-snaplock" is allowed to perform this operation.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
policy
_links  |
name  |
string  |
Specifies the EBR policy name  |
retention_period  |
string  |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
volume
_links  |
name  |
string  |
The name of the volume. This field cannot be specified in a POST or PATCH method.  |
uuid  |
string  |
ebr_operation
_links  |
id  |
integer  |
Operation ID  |
num_files_failed  |
integer  |
Specifies the number of files on which the application of EBR policy failed.  |
num_files_processed  |
integer  |
Specifies the number of files on which EBR policy was applied successfully.  |
num_files_skipped  |
integer  |
Specifies the number of files on which the application of EBR policy was skipped.  |
num_inodes_ignored  |
integer  |
Specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files.  |
path  |
string  |
The path for the EBR operation. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.  |
policy  |
state  |
string  |
Specifies the operation status of an EBR operation.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
volume  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
