Retrieve event retention policies for an SVM
Retrieves event retention policies for a storage virtual machine (SVM), giving you insight into the policies in place for retaining events.
HTTP method and endpoint
GET /storage/snaplock/event-retention/policies
Introduced in
ONTAP 9.7
Usage notes
Retrieves all event retention policies for an SVM.
Related ONTAP commands
snaplock event-retention policy show
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snaplock_retention_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"name": "string",
"retention_period": "P30M",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
name |
string |
Specifies the EBR policy name |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
