REST API reference
Retrieve event retention policies for an SVM
Accesses event retention policies for an SVM to review how long events are retained and managed within your storage system.
HTTP method and endpoint
GET /storage/snaplock/event-retention/policies
Introduced in
ONTAP 9.7
Usage notes
Retrieves all event retention policies for an SVM.
  • snaplock event-retention policy show
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snaplock_retention_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "string",
      "retention_period": "P30M",
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response codes
Error code Description
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format or infinite or unspecified.
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
_links
_links
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
