Retrieve AutoSupport message history
Accesses the AutoSupport message history from all nodes in the cluster. This helps you review and analyze recent AutoSupport messages for troubleshooting and operational insights.
HTTP method and endpoint
GET /support/autosupport/messages
Introduced in
ONTAP 9.6
Usage notes
Retrieves AutoSupport message history from all nodes in the cluster.
There can be a short delay on invoked AutoSupport messages showing in history, dependent on processing of other AutoSupports in the queue.
Related ONTAP commands
system node autosupport history show
Learn more
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
destination |
string |
query |
False |
Filter by destination |
state |
string |
query |
False |
Filter by state |
generated_on |
string |
query |
False |
Filter by generated_on |
index |
integer |
query |
False |
Filter by index |
subject |
string |
query |
False |
Filter by subject |
error.message |
string |
query |
False |
Filter by error.message |
error.code |
integer |
query |
False |
Filter by error.code |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[autosupport_message] |
List of messages invoked on the node |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"destination": "http",
"error": {
"code": 53149746,
"message": "Could not resolve host: test.com"
"generated_on": "2019-03-25T17:30:04-04:00",
"index": 9,
"node": {
"name": "node1",
"state": "sent_successful",
"subject": "WEEKLY_LOG"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
error
Last error during delivery attempt. Empty if "status=sent-successful".
code |
integer |
Error code |
message |
string |
Error message |
_links
self |
node
_links |
name |
string |
uuid |
string |
autosupport_message
destination |
string |
Destination for the AutoSupport |
error |
Last error during delivery attempt. Empty if "status=sent-successful". |
generated_on |
string |
Date and Time of AutoSupport generation in ISO-8601 format |
index |
integer |
Sequence number of the AutoSupport |
node |
state |
string |
State of AutoSupport delivery |
subject |
string |
Subject line for the AutoSupport |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
