REST API reference
Retrieve AutoSupport message history
Accesses the AutoSupport message history from all nodes in the cluster. This helps you review and analyze recent AutoSupport messages for troubleshooting and operational insights.
HTTP method and endpoint
GET /support/autosupport/messages
Introduced in
ONTAP 9.6
Usage notes
Retrieves AutoSupport message history from all nodes in the cluster.
There can be a short delay on invoked AutoSupport messages showing in history, dependent on processing of other AutoSupports in the queue.
  • system node autosupport history show
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
destination
string
query
False
Filter by destination
state
string
query
False
Filter by state
generated_on
string
query
False
Filter by generated_on
index
integer
query
False
Filter by index
subject
string
query
False
Filter by subject
error.message
string
query
False
Filter by error.message
error.code
integer
query
False
Filter by error.code
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
desc] direction. Default direction is 'asc' for ascending.
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[autosupport_message]
List of messages invoked on the node
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "destination": "http",
      "error": {
        "code": "53149746",
        "message": "Could not resolve host: test.com"
      "generated_on": "2019-03-25 17:30:04 -0400",
      "index": 9,
      "node": {
        "name": "node1",
      "state": "sent_successful",
      "subject": "WEEKLY_LOG"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
error
Last error during delivery attempt. Empty if "status=sent-successful".
code
integer
Error code
message
string
Error message
self
node
_links
_links
name
string
uuid
string
autosupport_message
destination
string
Destination for the AutoSupport
error
error
generated_on
string
Date and Time of AutoSupport generation in ISO-8601 format
index
integer
Sequence number of the AutoSupport
node
node
state
string
State of AutoSupport delivery
subject
string
Subject line for the AutoSupport
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
