Retrieve AutoSupport message history
GET /support/autosupport/messages
Retrieves AutoSupport message history from all nodes in the cluster.
There can be a short delay on invoked AutoSupport messages showing in history, dependent on processing of other AutoSupports in the queue.
Related ONTAP commands
system node autosupport history show
Learn more
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
destination |
string |
query |
False |
Filter by destination |
state |
string |
query |
False |
Filter by state |
generated_on |
string |
query |
False |
Filter by generated_on |
index |
integer |
query |
False |
Filter by index |
subject |
string |
query |
False |
Filter by subject |
error.message |
string |
query |
False |
Filter by error.message |
error.code |
integer |
query |
False |
Filter by error.code |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[autosupport_message] |
List of messages invoked on the node |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"destination": "http",
"error": {
"code": "53149746",
"message": "Could not resolve host: test.com"
"generated_on": "2019-03-25 17:30:04 -0400",
"index": 9,
"node": {
"name": "node1",
"state": "sent_successful",
"subject": "WEEKLY_LOG"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
error
Last error during delivery attempt. Empty if "status=sent-successful".
code |
integer |
Error code |
message |
string |
Error message |
_links
self |
node
_links |
name |
string |
uuid |
string |
autosupport_message
destination |
string |
Destination for the AutoSupport |
error |
Last error during delivery attempt. Empty if "status=sent-successful". |
generated_on |
string |
Date and Time of AutoSupport generation in ISO-8601 format |
index |
integer |
Sequence number of the AutoSupport |
node |
state |
string |
State of AutoSupport delivery |
subject |
string |
Subject line for the AutoSupport |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
