REST API reference
Retrieve an event filter
Retrieves an event filter to view the criteria used for filtering events in your ONTAP environment.
HTTP method and endpoint
GET /support/ems/filters/{name}
Introduced in
ONTAP 9.6
  • event filter show
name
string
path
True
Filter name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
name
string
Filter name
rules
array[rules]
Array of event filter rules on which to match.
system_defined
boolean
Flag indicating system-defined filters.
      "href": "/api/resourcelink"
  "name": "snmp-traphost",
  "rules": [
      "index": 1,
      "message_criteria": {
          "related": {
        "name_pattern": "callhome.*",
        "severities": "error,informational",
        "snmp_trap_types": "standard|built_in"
      "type": "include"
  "system_defined": 1
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
related
message_criteria
Matching message definitions for the filter. A property must be specified.
_links
_links
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
rules
Rule for an event filter
_links
_links
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
type
string
Rule type
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
