Retrieve an event filter
Retrieves an event filter to view the criteria used for filtering events in your ONTAP environment.
HTTP method and endpoint
GET /support/ems/filters/{name}
Introduced in
ONTAP 9.6
Related ONTAP commands
event filter show
name |
string |
path |
True |
Filter name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
access_control_role |
Indicates the access control role that created the event filter and is used to control access to the filter based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset. |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
system_defined |
boolean |
Flag indicating system-defined filters. |
"href": "/api/resourcelink"
"access_control_role": {
"name": "admin"
"name": "snmp-traphost",
"rules": [
"index": 1,
"message_criteria": {
"related": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"parameter_criteria": [
"name_pattern": "vol",
"value_pattern": "cloud*"
"type": "include"
"system_defined": 1
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
access_control_role
_links |
name |
string |
Role name |
_links
related |
message_criteria
Matching message definitions for the filter. A property must be specified.
_links |
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
parameter_criteria
Criterion used for parameter based filtering
name_pattern |
string |
Parameter name pattern. Wildcard character '*' is supported. |
value_pattern |
string |
Parameter value pattern. Wildcard character '*' is supported. |
rules
Rule for an event filter
_links |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
parameter_criteria |
array[parameter_criteria] |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters. |
type |
string |
Rule type |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
