REST API reference
Manage cluster firmware history
Retrieve a history of firmware update requests using this API. Utilize GET calls to access detailed records of past updates, which can be filtered to refine the results.
Overview
Use this API to retrieve a history of firmware update requests. This API supports GET calls.
Retrieving history of firmware updates
The following example retrieves a history of firmware updates performed on the cluster. Note that if the fields=* parameter is not specified, only the job ID and start time are returned. Filters can be added on the fields to limit the results.
# The API:
GET /api/cluster/firmware/history
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/firmware/history/?fields=*" -H "accept: application/hal+json"
# The response:
200 OK
"records": [
    "start_time": "1970-01-01T00:02:03+00:00",
    "job": {
      "uuid": "adf700c2-b50e-11ea-a54f-005056bbec43"
    "node": {
      "uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ee",
      "name": "node1"
    "fw_file_name": "all_disk_fw.zip",
    "fw_update_state": "starting_workers",
    "end_time": "1970-01-01T00:07:36+00:00",
    "update_status": [
        "worker": {
          "node": {
            "name": "node1"
          "state": "failed",
          "error": {
            "message": "A firmware file already exists.",
            "code": 2228327
        "worker": {
          "node": {
            "uuid": "0530d6c1-8c6d-11e8-907f-00a0985a72ef",
            "name": "node2"
          "state": "complete",
          "error": {
            "message": "Success",
            "code": 0
        "href": "/api/cluster/firmware/history/1970-01-01T00%3A02%3A03-00%3A00/adf700c2-b50e-11ea-a54f-005056bbec43"
    "job": {
      "uuid": "f84adabe-b50e-11ea-a54f-005056bbec43"
    "node": {
      "name": "node1"
    "fw_file_name": "all_shelf_fw.zip",
    "fw_update_state": "completed",
    "update_status": [
        "worker": {
          "node": {
            "name": "node1"
          "state": "failed",
          "error": {
            "code": 2228327
        "worker": {
          "node": {
            "name": "node2"
          "error": {
            "code": 0
        "href": "/api/cluster/firmware/history/1970-01-01T00%3A02%3A03-00%3A00/f84adabe-b50e-11ea-a54f-005056bbec43"
"num_records": 2,
    "href": "/api/cluster/firmware/history/?fields=%2A"
