REST API reference
Manage event destinations
Manage the list of event destinations to define where event information is transmitted. Use these endpoints to configure destinations such as email, syslog, REST API, and SNMP based on your notification requirements.
Overview
Manages the list of destinations. A destination is defined by a type and a place to which an event's information is transmitted.
Destination Types
An EMS destination is defined by a single type, which is one of the following:
  • email
  • syslog
  • rest_api
  • snmp
Email
The 'email' type allows you to define a mailbox where information about an observed event is sent by SMTP. Enter the address in the destination field in a valid format. For example: administrator@mycompany.com
Syslog
The 'syslog' type allows you to specify a remote syslog server that can receive information about an observed event. Enter the hostname or IP address in the destination field. For example: syslog.mycompany.com, 192.168.1.1
Rest API
The 'rest_api' type allows you to define a URL where information about an observed event is sent using the REST protocol. Enter the URL in the destination field. The URL must contain a valid transmission schema which can be one of the following:
  • http
  • https
Using the 'https' schema, you can configure a client-side certificate for mutual authentication. For example: http://rest.mycompany.com, https://192.168.1.1
SNMP
The 'snmp' type describes addresses where information about an observed event is sent using SNMP traps. The system defines a default instance of this type and it is restricted to read-only. This type has the following limitations:
  • Cannot create new destinations of type 'snmp'
  • Cannot modify the default 'snmp' destination
SNMP trap host details need to be configured through one of the following:
Type Command / API
CLI
'system snmp traphost'
ZAPI
'snmp-traphost-add' / 'snmp-traphost-delete'
Retrieving the list of active destinations
# The API:
GET /api/support/ems/destinations
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
    "name": "snmp-traphost",
        "href": "/api/support/ems/destinations/snmp-traphost"
"num_records": 1,
    "href": "/api/support/ems/destinations"
Creating a new 'email' destination
# The API:
POST /support/ems/destinations
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_destinations_post.txt"
test_ems_destinations_post.txt(body):
# JSON Body
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
  { "name" : "critical-wafl" }
# The response:
201 Created
