REST API reference
Manage event destinations
Manage event destinations to direct where event information is transmitted. Use these endpoints to define destinations based on types such as email, syslog, REST API, and SNMP, ensuring that event alerts are delivered to the appropriate location.
Overview
Manages the list of destinations. A destination is defined by a type and a place to which an event's information is transmitted.
Destination Types
An EMS destination is defined by a single type, which is one of the following:
  • email
  • syslog
  • rest_api
  • snmp
Email
The 'email' type allows you to define a mailbox where information about an observed event is sent by SMTP. Enter the address in the destination field in a valid format. For example: administrator@mycompany.com
Syslog
The 'syslog' type allows you to specify a remote syslog server that can receive information about an observed event. Enter the hostname or IP address in the destination field. For example: syslog.mycompany.com, 192.168.1.1
You can optionally specify the port and transport protocol to be used. The supported transport protocols are:
  • udp_unencrypted
  • tcp_unencrypted
  • tcp_encrypted
If transport is specified and the port is not specified, the default port for each transport is automatically selected. The default port for udp_unencrypted is 514, for tcp_unencrypted 601, and for tcp_encrypted 6514. The default transport protocol is udp_unencrypted.
The message format to be used can also be optionally specified. The supported message formats are:
  • legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG)
  • rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG)
If the default timestamp or hostname formats in the message format needs to be overridden, use timestamp_override and hostname_override properties.
The supported timestamp formats are:
  • no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424)
  • rfc_3164 (format: Mmm dd hh:mm:ss)
  • iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm)
  • iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ)
The supported hostname formats are:
  • no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp)
  • fqdn (Fully Qualified Domain Name)
  • hostname_only
Rest API
The 'rest_api' type allows you to define a URL where information about an observed event is sent using the REST protocol. Enter the URL in the destination field. The URL must contain a valid transmission schema which can be one of the following:
  • http
  • https
Using the https schema, you can configure a client-side certificate for mutual authentication. A client-side certificate is specified by the ca and serial_number fields in the certificate object. The name field of the certificate object is read-only and cannot be used to configure a client-side certificate.
SNMP
The 'snmp' type describes addresses where information about an observed event is sent using SNMP traps. The system defines a default instance of this type and it is restricted to read-only. This type has the following limitations:
  • Cannot create new destinations of type 'snmp'
  • Cannot modify the default 'snmp' destination
SNMP trap host details need to be configured through one of the following:
Type Command / API
CLI
'system snmp traphost'
ZAPI
'snmp-traphost-add' / 'snmp-traphost-delete'
Retrieving the list of active destinations
# The API:
GET /api/support/ems/destinations
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
    "name": "snmp-traphost",
        "href": "/api/support/ems/destinations/snmp-traphost"
"num_records": 1,
    "href": "/api/support/ems/destinations"
Creating a new 'email' destination
# The API:
POST /support/ems/destinations
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_destinations_post.txt"
test_ems_destinations_post.txt(body):
# JSON Body
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
  { "name" : "critical-wafl" }
# The response:
201 Created
Creating a new 'syslog' destination
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_destinations_syslog_post.txt"
test_ems_destinations_syslog_post.txt(body):
# JSON Body
"name": "Syslog_dest",
"type": "syslog",
"destination": "syslog.mycompany.com",
"syslog": {
  "port": 601,
  "transport": "tcp_unencrypted",
  "format": {
    "message": "rfc_5424",
    "hostname_override": "fqdn",
    "timestamp_override": "iso_8601_local_time"
"filters": [
# The response:
201 Created
