Manage LDAP schemas
Utilize these endpoints to manage and retrieve information about LDAP schemas within your network environment. These schemas are essential for integrating Active Directory and UNIX-based systems, ensuring seamless identity management across diverse platforms.
Overview
ONTAP provides four default LDAP schemas. These are:
MS-AD-BIS Based on RFC-2307bis. This is the preferred LDAP schema for most standard Windows 2012 and later LDAP deployments.
AD-IDMU Based on Active Directory Identity Management for UNIX. This schema is appropriate for most Windows 2008, Windows 2012, and later AD servers.
AD-SFU Based on Active Directory Services for UNIX. This schema is appropriate for most Windows 2003 and earlier AD servers.
RFC-2307 Based on RFC-2307 (an approach that uses LDAP as a network information service). This schema is appropriate for most UNIX AD servers.
Retrieving LDAP schema information
# The API:
GET /api/name-services/ldap-schemas
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/ldap-schemas"
# The response:
"records": [
"owner": {
"uuid": "eda950c6-0a0c-11ec-bfcf-0050568e9150",
"name": "athiraacluster-1",
"href": "/api/svm/svms/eda950c6-0a0c-11ec-bfcf-0050568e9150"
"name": "AD-IDMU",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/AD-IDMU"
"owner": {
"name": "AD-SFU",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/AD-SFU"
"owner": {
"name": "MS-AD-BIS",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/MS-AD-BIS"
"owner": {
"name": "RFC-2307",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/RFC-2307"
"num_records": 4,
"href": "/api/name-services/ldap-schemas"
Retrieving LDAP schema information for a given SVM and "name"
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/RFC-2307"
# The response:
"owner": {
"name": "svm1",
"name": "RFC-2307",
"comment": "Schema based on RFC 2307 (read-only)",
"name_mapping": {
"account": {
"unix": "unixAccount",
"windows": "windowsAccount"
"windows_to_unix": {
"attribute": "windowsAccount",
"no_domain_prefix": false,
"object_class": "posixAccount"
"rfc2307": {
"attribute": {
"gecos": "gecos",
"gid_number": "gidNumber",
"home_directory": "homeDirectory",
"login_shell": "loginShell",
"uid": "uid",
"uid_number": "uidNumber",
"user_password": "userPassword"
"cn": {
"group": "cn",
"netgroup": "cn"
"member": {
"nis_netgroup": "memberNisNetgroup",
"uid": "memberUid"
"nis": {
"netgroup_triple": "nisNetgroupTriple",
"netgroup": "nisNetgroup",
"object": "nisObject",
"mapname": "nisMapName",
"mapentry": "nisMapEntry"
"posix": {
"account": "posixAccount",
"group": "posixGroup"
"rfc2307bis": {
"enabled": false,
"group_of_unique_names": "groupOfUniqueNames",
"maximum_groups": 256,
"unique_member": "uniqueMember"
"scope": "cluster",
"global_schema": true,
Creating an LDAP schema
# The API:
POST /api/name-services/ldap-schemas
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/ldap-schemas" -H "accept: application/json" -H "autorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"name\": \"schema\",\"template\": { \"name\": \"AD-IDMU\" }, \"owner\": { \"uuid\": \"52ba8197-0a23-11ec-9622-0050568e9150\", \"name\" : \"svm1\" }}"
Updating an LDAP schema
# The API:
PATCH /api/name-services/ldap-schemas/{owner.uuid}/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/ldap-schemas/52ba8197-0a23-11ec-9622-0050568e9150/schema" -H "autorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"comment\": \"This is a comment for schema\"}"
Deleting an LDAP schema
# The API:
DELETE /api/name-services/ldap-schemas/{owner.uuid}/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/ldap-schemas/52ba8197-0a23-11ec-9622-0050568e9150/schema"
