Manage LDAP schemas
Explore LDAP schema management with these endpoints, which handle retrieval, creation, updating, and deletion of LDAP schema configurations. Use these endpoints to customize and maintain LDAP settings for various server environments, ensuring compatibility and effective identity management.
Overview
ONTAP provides four default LDAP schemas. These are:
MS-AD-BIS Based on RFC-2307bis. This is the preferred LDAP schema for most standard Windows 2012 and later LDAP deployments.
AD-IDMU Based on Active Directory Identity Management for UNIX. This schema is appropriate for most Windows 2008, Windows 2012, and later AD servers.
AD-SFU Based on Active Directory Services for UNIX. This schema is appropriate for most Windows 2003 and earlier AD servers.
RFC-2307 Based on RFC-2307 (an approach that uses LDAP as a network information service). This schema is appropriate for most UNIX AD servers.
Retrieving LDAP schema information
# The API:
GET /api/name-services/ldap-schemas
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/ldap-schemas"
# The response:
"records": [
"owner": {
"uuid": "eda950c6-0a0c-11ec-bfcf-0050568e9150",
"name": "athiraacluster-1",
"href": "/api/svm/svms/eda950c6-0a0c-11ec-bfcf-0050568e9150"
"name": "AD-IDMU",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/AD-IDMU"
"owner": {
"name": "AD-SFU",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/AD-SFU"
"owner": {
"name": "MS-AD-BIS",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/MS-AD-BIS"
"owner": {
"name": "RFC-2307",
"href": "/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/RFC-2307"
"num_records": 4,
"href": "/api/name-services/ldap-schemas"
Retrieving LDAP schema information for a given SVM and "name"
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/ldap-schemas/eda950c6-0a0c-11ec-bfcf-0050568e9150/RFC-2307"
# The response:
"owner": {
"name": "svm1",
"name": "RFC-2307",
"comment": "Schema based on RFC 2307 (read-only)",
"name_mapping": {
"account": {
"unix": "unixAccount",
"windows": "windowsAccount"
"windows_to_unix": {
"attribute": "windowsAccount",
"no_domain_prefix": false,
"object_class": "posixAccount"
"rfc2307": {
"attribute": {
"gecos": "gecos",
"gid_number": "gidNumber",
"home_directory": "homeDirectory",
"login_shell": "loginShell",
"uid": "uid",
"uid_number": "uidNumber",
"user_password": "userPassword"
"cn": {
"group": "cn",
"netgroup": "cn"
"member": {
"nis_netgroup": "memberNisNetgroup",
"uid": "memberUid"
"nis": {
"netgroup_triple": "nisNetgroupTriple",
"netgroup": "nisNetgroup",
"object": "nisObject",
"mapname": "nisMapName",
"mapentry": "nisMapEntry"
"posix": {
"account": "posixAccount",
"group": "posixGroup"
"rfc2307bis": {
"enabled": false,
"group_of_unique_names": "groupOfUniqueNames",
"maximum_groups": 256,
"unique_member": "uniqueMember"
"scope": "cluster",
"global_schema": true,
Creating an LDAP schema
# The API:
POST /api/name-services/ldap-schemas
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/ldap-schemas" -H "accept: application/json" -H "authorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"name\": \"schema\",\"template\": { \"name\": \"AD-IDMU\" }, \"owner\": { \"uuid\": \"52ba8197-0a23-11ec-9622-0050568e9150\", \"name\" : \"svm1\" }}"
Updating an LDAP schema
# The API:
PATCH /api/name-services/ldap-schemas/{owner.uuid}/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/ldap-schemas/52ba8197-0a23-11ec-9622-0050568e9150/schema" -H "authorization: Basic YWRtaW46bmV0YXBwMSE=" -H "Content-Type: application/json" -d "{ \"comment\": \"This is a comment for schema\"}"
Deleting an LDAP schema
# The API:
DELETE /api/name-services/ldap-schemas/{owner.uuid}/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/ldap-schemas/52ba8197-0a23-11ec-9622-0050568e9150/schema"
