Manage storage aggregate plexes
Manage storage aggregate plexes with the Storage Aggregate Plex API to access detailed state information for each plex, including RAID group and disk composition.
Overview
The Storage Aggregate Plex API provides relevant state information for each plex in the aggregate. For each plex, details are provided for the RAID groups in the plex and the disks that make up each RAID group.
Retrieving all aggregates and plexes
The following example shows the response with a list of aggregates and plexes:
The call:
curl -X GET "https://
The response:
{ "records": [ { "aggregate": { "uuid": "04b7296e-a302-42a6-a2a9-dda6be054b29", "name": "test2" }, "name": "plex0" }, { "aggregate": { "uuid": "04b7296e-a302-42a6-a2a9-dda6be054b29", "name": "test2" }, "name": "plex1", }, { "aggregate": { "uuid": "66c4b221-65ff-4211-9b58-ada3c6fc41af", "name": "test" }, "name": "plex0" }, { "aggregate": { "uuid": "66c4b221-65ff-4211-9b58-ada3c6fc41af", "name": "test" }, "name": "plex1" }, { "aggregate": { "uuid": "7ee89e48-5d81-4609-9e1b-5d8d0995a886", "name": "aggr1", }, "name": "plex0", }, { "aggregate": { "uuid": "8bb2e3bf-c4f1-4748-9033-ca9231cf1c40", "name": "test3", }, "name": "plex0", }, { "aggregate": { "uuid": "8bb2e3bf-c4f1-4748-9033-ca9231cf1c40", "name": "test3", }, "name": "plex1" }, { "aggregate": { "uuid": "8f13de5c-99cf-4ada-884c-3cc32deb304a", "name": "aggr2", }, "name": "plex0" } ], "num_records": 8 }
### Retrieving a specific plex in all aggregates
The following example shows the response with a list of specific plexes in all aggregates:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/*/plexes/plex0" -H "accept: application/json"
# The response:
"records": [
"aggregate": {
"name": "test2"
"name": "plex0"
"aggregate": {
"name": "test"
"name": "plex0"
"aggregate": {
"name": "aggr1",
"name": "plex0",
"aggregate": {
"name": "test3",
"name": "plex0",
"aggregate": {
"name": "aggr2",
"name": "plex0"
"num_records": 8
Retrieving the list of plexes in an aggregate
The following example shows the response with the list of plexes in an aggregate:
# The API:
/api/storage/aggregates/{uuid}/plexes
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/19425837-f2fa-4a9f-8f01-712f626c983c/plexes" -H "accept: application/json"
# The response:
"records": [
"name": "plex0",
"name": "plex4",
"num_records": 2,
Retrieving a specific plex in an aggregate
The following example shows the response when requesting a specific plex of an aggregate:
# The API:
/api/storage/aggregates/{uuid}/plexes/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/19425837-f2fa-4a9f-8f01-712f626c983c/plexes/plex0" -H "accept: application/json"
# The response:
"aggregate": {
"uuid": "19425837-f2fa-4a9f-8f01-712f626c983c",
"name": "test1",
"name": "plex0",
"online": true,
"state": "normal",
"pool": "pool0",
"resync": {
"active": false
"raid_groups": [
"name": "rg0",
"raid_type": "raid_dp",
"cache_tier": false,
"degraded": false,
"recomputing_parity": {
"active": false
"reconstruct": {
"active": false
"disks": [
"position": "dparity",
"state": "normal",
"type": "ssd",
"usable_size": 86769664,
"disk": {
"name": "1.1.29",
"position": "parity",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.4",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.30",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.5",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.31",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.6",
