Manage storage aggregate plexes
Retrieve state information for storage aggregate plexes, detailing the RAID groups and disks within each plex. Use these endpoints to monitor and manage the configuration of your storage aggregates effectively.
Overview
The Storage Aggregate Plex API provides relevant state information for each plex in the aggregate. For each plex, details are provided for the RAID groups in the plex and the disks that make up each RAID group.
Retrieving the list of plexes in an aggregate
The following example shows the response with the list of plexes in an aggregate:
# The API:
/api/storage/aggregates/{uuid}/plexes
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/19425837-f2fa-4a9f-8f01-712f626c983c/plexes" -H "accept: application/json"
# The response:
"records": [
"name": "plex0",
"name": "plex4",
"num_records": 2,
Retrieving a specific plex in an aggregate
The following example shows the response when requesting a specific plex of an aggregate:
# The API:
/api/storage/aggregates/{uuid}/plexes/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/aggregates/19425837-f2fa-4a9f-8f01-712f626c983c/plexes/plex0" -H "accept: application/json"
# The response:
"aggregate": {
"uuid": "19425837-f2fa-4a9f-8f01-712f626c983c",
"name": "test1",
"name": "plex0",
"online": true,
"state": "normal",
"pool": "pool0",
"resync": {
"active": false
"raid_groups": [
"name": "rg0",
"raid_type": "raid_dp",
"cache_tier": false,
"degraded": false,
"recomputing_parity": {
"active": false
"reconstruct": {
"active": false
"disks": [
"position": "dparity",
"state": "normal",
"type": "ssd",
"usable_size": 86769664,
"disk": {
"name": "1.1.29",
"position": "parity",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.4",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.30",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.5",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.31",
"position": "data",
"state": "normal",
"type": "ssd",
"disk": {
"name": "1.1.6",
