REST API reference
Update UNIX group cache settings
Updates UNIX group cache settings to modify how the system manages cached UNIX group information. Use this endpoint to adjust configurations for improved cache performance or to align with specific administrative policies.
HTTP method and endpoint
PATCH /name-services/cache/unix-group/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates unix-group cache settings.
Important notes
  • svm.uuid field cannot be empty.
  • Returns success in case no values are provided for update.
  • vserver services name-service cache unix-group settings modify
svm.uuid
string
path
True
SVM UUID.
Request Body
Name Type Description
enabled
boolean
Indicates whether or not the cache is enabled.
negative_cache_enabled
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl
string
Specifies negative Time to Live, in ISO 8601 format.
propagation_enabled
boolean
Specifies whether the propagation setting is enabled or not.
svm
svm
ttl
string
Specifies Time to Live (TTL), in ISO 8601 format.
Example request
  "negative_ttl": "PT5M",
  "svm": {
    "name": "svm1",
  "ttl": "PT24H"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
23724055
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support.
string
svm
name
string
The name of the SVM.
uuid
string
unix_group_settings
UNIX groups cache setting.
enabled
boolean
boolean
negative_ttl
string
propagation_enabled
boolean
svm
svm
ttl
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
