Update UNIX group cache settings
Updates UNIX group cache settings to modify the caching behavior for UNIX group information in your storage environment. This can be useful when adjusting the cache to improve performance or adapt to changes in group configurations.
HTTP method and endpoint
PATCH /name-services/cache/unix-group/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates unix-group cache settings.
Important notes
svm.uuid field cannot be empty.
Returns success in case no values are provided for update.
Related ONTAP commands
vserver services name-service cache unix-group settings modify
Learn more
svm.uuid |
string |
path |
True |
SVM UUID. |
Request Body
| Name | Type | Description |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
negative_cache_enabled |
boolean |
Indicates whether or not the negative cache is enabled. |
negative_ttl |
string |
Specifies negative Time to Live, in ISO 8601 format. |
propagation_enabled |
boolean |
Specifies whether the propagation setting is enabled or not. |
svm |
ttl |
string |
Specifies Time to Live (TTL), in ISO 8601 format. |
Example request
"negative_ttl": "PT5M",
"svm": {
"name": "svm1",
"ttl": "PT24H"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
unix_group_settings
UNIX groups cache setting.
enabled |
boolean |
boolean |
negative_ttl |
string |
boolean |
svm |
ttl |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
