REST API reference
Manage UNIX group cache settings
Access and manage UNIX group cache settings using this API to optimize directory service interactions. Retrieve current cache configurations or update them as needed to ensure efficient access control management within your environment.
Overview
This API is used to retrieve and manage unix-group settings.
Retrieving unix-group settings
The following example shows how to use the cache unix-group settings GET endpoint to retrieve unix-group cache settings.
# The API:
GET /api/name-services/cache/unix-group/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-group/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
      "name": "vs43"
    "enabled": true,
    "negative_cache_enabled": true,
    "ttl": "P1D",
    "negative_ttl": "PT1M",
    "propagation_enabled": true
    "svm": {
      "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
      "name": "vs34"
    "enabled": true,
    "ttl": "P1D",
"num_records": 2
Retrieving a unix-group setting for a given SVM
The following example shows how to use the cache unix-group settings GET endpoint to retrieve unix-group cache settings for a given SVM.
# The API:
GET /api/name-services/cache/unix-group/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-group/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs34"
"enabled": true,
"ttl": "P1D",
Updating a unix-group setting
The following example shows how to use the cache unix-group settings PATCH endpoint to update unix-group cache settings for an SVM.
# The API:
PATCH /api/name-services/cache/unix-group/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/unix-group/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"ttl\": \"PT2H\", \"negative_ttl\": \"PT2M\" }"
