REST API reference
Manage UNIX group cache settings
Retrieve and manage UNIX group cache settings using this API to optimize your name services configuration. Access endpoints to get current settings or update them for specific storage virtual machines (SVMs).
Overview
This API is used to retrieve and manage unix-group settings.
Retrieving unix-group settings
The following example shows how to use the cache unix-group settings GET endpoint to retrieve unix-group cache settings.
# The API:
GET /api/name-services/cache/unix-group/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-group/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
      "name": "vs43"
    "enabled": true,
    "negative_cache_enabled": true,
    "ttl": "P1D",
    "negative_ttl": "PT1M",
    "propagation_enabled": true
    "svm": {
      "uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
      "name": "vs34"
    "enabled": true,
    "ttl": "P1D",
"num_records": 2
Retrieving a unix-group setting for a given SVM
The following example shows how to use the cache unix-group settings GET endpoint to retrieve unix-group cache settings for a given SVM.
# The API:
GET /api/name-services/cache/unix-group/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-group/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
  "name": "vs34"
"enabled": true,
"ttl": "P1D",
Updating a unix-group setting
The following example shows how to use the cache unix-group settings PATCH endpoint to update unix-group cache settings for an SVM.
# The API:
PATCH /api/name-services/cache/unix-group/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/unix-group/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"ttl\": \"PT2H\", \"negative_ttl\": \"PT2M\" }"
