Manage UNIX group cache settings
Manage UNIX group cache settings to retrieve and modify cache configurations for UNIX groups. Use these endpoints to access current settings or update them for a given Storage Virtual Machine (SVM).
Overview
This API is used to retrieve and manage unix-group settings.
Retrieving unix-group settings
The following example shows how to use the cache unix-group settings GET endpoint to retrieve unix-group cache settings.
# The API:
GET /api/name-services/cache/unix-group/settings
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-group/settings?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "8a1a8730-2036-11ec-8457-005056bbcfdb",
"name": "vs43"
"enabled": true,
"negative_cache_enabled": true,
"ttl": "P1D",
"negative_ttl": "PT1M",
"propagation_enabled": true
"svm": {
"uuid": "dc458b2f-2035-11ec-bfe2-005056bb6bef",
"name": "vs34"
"enabled": true,
"ttl": "P1D",
"num_records": 2
Retrieving a unix-group setting for a given SVM
The following example shows how to use the cache unix-group settings GET endpoint to retrieve unix-group cache settings for a given SVM.
# The API:
GET /api/name-services/cache/unix-group/settings/{svm.uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/cache/unix-group/settings/dc458b2f-2035-11ec-bfe2-005056bb6bef" -H "accept: application/hal+json"
# The response:
"svm": {
"name": "vs34"
"enabled": true,
"ttl": "P1D",
Updating a unix-group setting
The following example shows how to use the cache unix-group settings PATCH endpoint to update unix-group cache settings for an SVM.
# The API:
PATCH /api/name-services/cache/unix-group/settings/{svm.uuid}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/cache/unix-group/settings/02c9e252-41be-11e9-81d5-00a0986138f9" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"ttl\": \"PT2H\", \"negative_ttl\": \"PT2M\" }"
