Update LDAP schema details for an owner and schema
Updates the LDAP schema details for a specific owner and schema. Use this endpoint to customize LDAP schemas that you own, ensuring they meet your directory service requirements.
HTTP method and endpoint
PATCH /name-services/ldap-schemas/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
Usage notes
Updates LDAP schema details for a given owner and schema.
Important notes
The default LDAP schemas provided by ONTAP cannot be modified.
LDAP schemas can only be modified by the owner of the schema.
Related ONTAP commands
vserver services name-service ldap client schema modify
owner.uuid |
string |
path |
True |
UUID of the owner to which this object belongs. |
name |
string |
path |
True |
LDAP schema name. |
Request Body
| Name | Type | Description |
comment |
string |
Comment to associate with the schema. |
global_schema |
boolean |
A global schema that can be used by all the SVMs. |
name_mapping |
owner |
rfc2307 |
rfc2307bis |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"comment": "Schema based on Active Directory Services for UNIX (read-only).",
"global_schema": 1,
"name_mapping": {
"account": {
"unix": "windowsAccount",
"windows": "windowsAccount"
"windows_to_unix": {
"attribute": "windowsAccount",
"no_domain_prefix": "",
"object_class": "User"
"owner": {
"name": "svm1",
"rfc2307": {
"attribute": {
"gecos": "name",
"gid_number": "msSFU30GidNumber",
"home_directory": "msSFU30HomeDirectory",
"login_shell": "msSFU30LoginShell",
"uid": "sAMAccountName",
"uid_number": "msSFU30UidNumber",
"user_password": "msSFU30Password"
"cn": {
"group": "cn",
"netgroup": "name"
"member": {
"nis_netgroup": "msSFU30MemberNisNetgroup",
"uid": "msSFU30MemberUid"
"nis": {
"mapentry": "msSFU30NisMapEntry",
"mapname": "msSFU30NisMapName",
"netgroup": "msSFU30NisNetGroup",
"netgroup_triple": "msSFU30MemberOfNisNetgroup",
"object": "msSFU30NisObject"
"posix": {
"account": "User",
"group": "Group"
"rfc2307bis": {
"enabled": "",
"group_of_unique_names": "groupOfUniqueNames",
"maximum_groups": 256,
"unique_member": "uniqueMember"
"scope": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4915205 |
The LDAP schema is a default schema and cannot be modified or deleted. |
4915217 |
LDAP schema is owned by the admin SVM. |
4915223 |
LDAP schema does not belong to the admin SVM. |
href |
string |
_links
ldap_schema_account
unix |
string |
Attribute name used to retrieve UNIX account information. |
windows |
string |
Attribute name used to retrieve Windows account information for a UNIX user account. |
windows_to_unix
attribute |
string |
Attribute name used to retrieve the UNIX account information for a Windows user account. |
no_domain_prefix |
boolean |
Indicates whether or not the name for Windows to UNIX name mapping should have a domain prefix. |
object_class |
string |
Name used to represent the windowsToUnix object class. |
ldap_schema_name_mapping
account |
windows_to_unix |
owner
name |
string |
The name of the SVM. |
uuid |
string |
attribute
gecos |
string |
RFC 2307 gecos attribute. |
gid_number |
string |
RFC 2307 gidNumber attribute. |
home_directory |
string |
RFC 2307 homeDirectory attribute. |
login_shell |
string |
RFC 2307 loginShell attribute. |
uid |
string |
RFC 1274 userid attribute used by RFC 2307 as UID. |
uid_number |
string |
RFC 2307 uidNumber attribute. |
user_password |
string |
RFC 2256 userPassword attribute used by RFC 2307. |
cn
group |
string |
RFC 2256 cn attribute used by RFC 2307 when working with groups. |
netgroup |
string |
RFC 2256 cn attribute used by RFC 2307 when working with netgroups. |
member
nis_netgroup |
string |
RFC 2307 memberNisNetgroup attribute. |
uid |
string |
RFC 2307 memberUid attribute. |
nis
mapentry |
string |
RFC 2307 nisMapEntry attribute. |
mapname |
string |
RFC 2307 nisMapName attribute. |
netgroup |
string |
RFC 2307 nisNetgroup object class. |
netgroup_triple |
string |
RFC 2307 nisNetgroupTriple attribute. |
object |
string |
RFC 2307 nisObject object class. |
posix
account |
string |
RFC 2307 posixAccount object class. |
group |
string |
RFC 2307 posixGroup object class. |
rfc2307
attribute |
cn |
member |
nis |
posix |
rfc2307bis
enabled |
boolean |
Indicates whether RFC 2307bis is enabled for the client schema. |
group_of_unique_names |
string |
RFC 2307bis groupOfUniqueNames object class. |
maximum_groups |
integer |
Maximum number of groups supported when RFC 2307bis is enabled. |
unique_member |
string |
RFC 2307bis uniqueMember attribute. |
template
The existing schema template you want to copy.
name |
string |
The name of the schema. |
ldap_schema
comment |
string |
global_schema |
boolean |
name_mapping |
owner |
rfc2307 |
rfc2307bis |
scope |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
