REST API reference
Update the LDAP schema details for an owner and schema
Updates the LDAP schema details for a specific owner and schema. Use this endpoint to customize LDAP schemas that you own, ensuring they meet your directory service requirements.
HTTP method and endpoint
PATCH /name-services/ldap-schemas/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
Usage notes
Updates LDAP schema details for a given owner and schema.
Important notes
  • The default LDAP schemas provided by ONTAP cannot be modified.
  • LDAP schemas can only be modified by the owner of the schema.
  • vserver services name-service ldap client schema modify
owner.uuid
string
path
True
UUID of the owner to which this object belongs.
name
string
path
True
LDAP schema name.
Request Body
Name Type Description
comment
string
Comment to associate with the schema.
global_schema
boolean
A global schema that can be used by all the SVMs.
name_mapping
ldap_schema_name_mapping
rfc2307
rfc2307
rfc2307bis
rfc2307bis
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
Example request
  "comment": "Schema based on Active Directory Services for UNIX (read-only).",
  "global_schema": 1,
  "name_mapping": {
    "account": {
      "unix": "windowsAccount",
      "windows": "windowsAccount"
    "windows_to_unix": {
      "attribute": "windowsAccount",
      "no_domain_prefix": "",
      "object_class": "User"
  "rfc2307": {
    "attribute": {
      "gecos": "name",
      "gid_number": "msSFU30GidNumber",
      "home_directory": "msSFU30HomeDirectory",
      "login_shell": "msSFU30LoginShell",
      "uid": "sAMAccountName",
      "uid_number": "msSFU30UidNumber",
      "user_password": "msSFU30Password"
    "cn": {
      "group": "cn",
      "netgroup": "name"
    "member": {
      "nis_netgroup": "msSFU30MemberNisNetgroup",
      "uid": "msSFU30MemberUid"
    "nis": {
      "mapentry": "msSFU30NisMapEntry",
      "mapname": "msSFU30NisMapName",
      "netgroup": "msSFU30NisNetGroup",
      "netgroup_triple": "msSFU30MemberOfNisNetgroup",
      "object": "msSFU30NisObject"
    "posix": {
      "account": "User",
      "group": "Group"
  "rfc2307bis": {
    "enabled": "",
    "group_of_unique_names": "groupOfUniqueNames",
    "maximum_groups": 256,
    "unique_member": "uniqueMember"
  "scope": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
4915205
The LDAP schema is a default schema and cannot be modified or deleted.
4915217
LDAP schema is owned by the admin SVM.
4915223
LDAP schema does not belong to the admin SVM.
string
ldap_schema_account
unix
string
Attribute name used to retrieve UNIX account information.
windows
string
Attribute name used to retrieve Windows account information for a UNIX user account.
windows_to_unix
attribute
string
Attribute name used to retrieve the UNIX account information for a Windows user account.
no_domain_prefix
boolean
Indicates whether or not the name for Windows to UNIX name mapping should have a domain prefix.
object_class
string
Name used to represent the windowsToUnix object class.
account
ldap_schema_account
windows_to_unix
windows_to_unix
owner
name
string
uuid
string
attribute
gecos
string
RFC 2307 gecos attribute.
gid_number
string
RFC 2307 gidNumber attribute.
home_directory
string
RFC 2307 homeDirectory attribute.
login_shell
string
RFC 2307 loginShell attribute.
uid
string
RFC 1274 userid attribute used by RFC 2307 as UID.
uid_number
string
RFC 2307 uidNumber attribute.
user_password
string
RFC 2256 userPassword attribute used by RFC 2307.
cn
group
string
RFC 2256 cn attribute used by RFC 2307 when working with groups.
netgroup
string
RFC 2256 cn attribute used by RFC 2307 when working with netgroups.
member
nis_netgroup
string
RFC 2307 memberNisNetgroup attribute.
uid
string
RFC 2307 memberUid attribute.
nis
mapentry
string
RFC 2307 nisMapEntry attribute.
mapname
string
RFC 2307 nisMapName attribute.
netgroup
string
RFC 2307 nisNetgroup object class.
netgroup_triple
string
RFC 2307 nisNetgroupTriple attribute.
object
string
RFC 2307 nisObject object class.
posix
account
string
RFC 2307 posixAccount object class.
group
string
RFC 2307 posixGroup object class.
rfc2307
attribute
attribute
cn
cn
member
member
nis
nis
posix
posix
rfc2307bis
enabled
boolean
Indicates whether RFC 2307bis is enabled for the client schema.
string
RFC 2307bis groupOfUniqueNames object class.
maximum_groups
integer
Maximum number of groups supported when RFC 2307bis is enabled.
unique_member
string
RFC 2307bis uniqueMember attribute.
template
The existing schema template you want to copy.
name
string
The name of the schema.
ldap_schema
comment
string
global_schema
boolean
name_mapping
rfc2307
rfc2307
rfc2307bis
rfc2307bis
scope
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
